96 ek coupe problems
Old Mar 16, 2008 | 09:51 AM
dareddarkness's Avatar
Default 96 ek coupe problems
so i got a 96 coupe with a b18b1 and now i am blowing the fuse for my ecu and have no idea where the short is. I checked all my wires and i found some open wires and fixed them but it's still blowing that fuse what should i do?
Old Mar 16, 2008 | 10:00 AM
Former User's Avatar
Default Re: 96 ek coupe problems (dareddarkness)
Is fuse 31 blowing? If so, this fuse protects not only the ECU but also the main relay and integrated control unit. Disconnect each component individually to localize the source of the electrical short.
Old Mar 16, 2008 | 10:03 AM
Default Re: 96 ek coupe problems (RonJ@HT)
so disconnect both the main relay and the ecu
Old Mar 16, 2008 | 10:11 AM
Can I assume that the fuse blows when you turn the ignition key to ON?
If so, you can disconnect either the ECU, main relay, or integrated control unit connector(s) (one at a time), turn the ignition key to ON, and identify the disconnected component that blocks the fuse from blowing.
Old Mar 16, 2008 | 10:16 AM
cool thnx but the fuse blows when i am driving then when i replace it that's when it blows when i just turn the key
maestrotwo
51
Apr 4, 2016 04:23 PM
91b18a1ls
Nov 23, 2010 11:29 AM
SlepT ej6
32
Feb 14, 2010 01:05 PM
Racewerkz
Dec 12, 2006 12:01 PM
93turbo16
Jun 18, 2006 12:19 PM
