Is LSD better or worse for drag?
Old Mar 16, 2008 | 08:49 AM
boosted95gsr's Avatar
Default Is LSD better or worse for drag?
I have a turbo 95 GSR used for street driving and drag, i was looking into putting in an ITR LSD but not sure if i would bennefit. Any sugguestions?
Old Mar 16, 2008 | 11:19 AM
blkb18's Avatar
Default Re: Is LSD better or worse for drag? (boosted95gsr)
Increased traction can never be bad. If your running high boost you may want to look into a helical diff like a quaiffe.
Old Mar 16, 2008 | 02:19 PM
Schister66's Avatar
Man U FTW
If you're going to buy an LSD, dont bother with the ITR LSD, opt for the Quaife instead.
Old Mar 16, 2008 | 02:45 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Is LSD better or worse for drag? (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">Increased traction can never be bad. If your running high boost you may want to look into a helical diff like a quaiffe.</TD></TR></TABLE>
Both the ITR and Quaife units are helical LSDs. They are torque biasing units which means that they act like an open differential if one wheel has no traction. Neither likes wheel hop. For drag racing, a clutch pack unit is superior.
What is your WHP?
Old Mar 16, 2008 | 02:55 PM
Spleen's Avatar
Correct me if i'm wrong, i'm still a Honda noob coming from a DSM, but I thought the ITR LSD wasn't compatible with the GSR tranny and the LS tranny? Or maybe it's just the LS tranny? Or there's a good chance I have no idea what i'm talking about. I don't know, but someone please enlighten me.
Old Mar 16, 2008 | 02:59 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Is LSD better or worse for drag? (Spleen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spleen &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if i'm wrong, i'm still a Honda noob coming from a DSM, but I thought the ITR LSD wasn't compatible with the GSR tranny and the LS tranny? Or maybe it's just the LS tranny? Or there's a good chance I have no idea what i'm talking about. I don't know, but someone please enlighten me.</TD></TR></TABLE>
The GSR and ITR transmissions share the same case. The ITR LSD is a direct swap into the GSR. (I did this on my GSR.) I recall it being compatible with the LS transmission with slight modification.
Old Mar 16, 2008 | 03:12 PM
Default Re: Is LSD better or worse for drag? (Dogginator)
I am currently at about 300whp on 9lbs, as soon as i decide what to do with my tranny i am going for a 20lb tune and aiming for 450-500whp. Right now i have a phantom grip lsd block on my GSR diff., and dont know if i should use that or run my GSR diff stock. Money is tight and i need a simple solution.
zeroz
Jan 11, 2006 01:26 AM
allmotorhonda
Dec 6, 2002 06:30 AM
ILOVEGIRLS
Feb 18, 2002 12:17 AM
dragster
Dec 9, 2001 11:34 PM
