wiring problem ****PICS****
Old Mar 16, 2008 | 06:01 AM
MrMug3n's Avatar
Default wiring problem ****PICS****
in search of the reason why my windows and wipers just stoped working i found out that the new delsol i just got a month ago has crazy wiring issues! tore the dash and ive pulled almost 30 wires not conected and started to clean up bare wires to reduce any shorts.
strpped
no dash
no dash 2
g401
another ground
Old Mar 16, 2008 | 06:02 AM
MrMug3n's Avatar
Default Re: wiring problem ****PICS**** (MrMug3n)
Old Mar 16, 2008 | 06:13 AM
MrMug3n's Avatar
Old Mar 16, 2008 | 06:52 AM
crazyguy's Avatar
oh wow dude. thats a lot of work to pull all the dash and panels off and try to figure out the wiring.
u the man
Old Mar 16, 2008 | 06:56 AM
SwapKing0917's Avatar
Default Re: wiring problem ****PICS**** (crazyguy)
I just finished my del sol from striping it and putting it back together
if you need help let me know I also have basically all the wiring
let me know
Old Mar 16, 2008 | 07:05 AM
MrMug3n's Avatar
Default Re: wiring problem ****PICS**** (SwapKing0917)
idk i hate wiring! ive ran thru this car looking for shorts or loose grounds. I have cleand up any bare wires and still no windows or wipers
Old Mar 16, 2008 | 07:14 AM
JDM_SOHC's Avatar
what are the chances of all the motors for those things goin bad at the same time..?? are they interconnected somehow..?? those are ?'s id be askin... i hit a huge chain in the road on I75 now to long ago, an doin about 85mph an hittin that thing felt like i ran through the worlds biggest pothole, well right after that my whole dash stopped working, turn signals stopped working, an couple other things... well it came to be i hit so hard that i popped a couple fuses... wtf right..?? i never thought hittin something in the road would pop a fuse but hey im living proof man, so dont be scared to ask the crazy ?'s...
Old Mar 16, 2008 | 03:26 PM
Did the car have an alarm and then was taken out you might want to look into that and module for the windows located by the srs module
Old Mar 16, 2008 | 04:21 PM
icemanAKA92eg6's Avatar
New User
do u have a wiring diagram to look @ to see if there r any relays or fuses they share. if u dont pick up a helms manuel for 92-95 civic @ the zone. try a jumper wire to make sure its not the driver side window switch or wiper switch. but its not to common for both to go out @ the same time. if all else fails pick up a new harness on ebay nothing like a fresh uncut harness!
Old Mar 16, 2008 | 05:39 PM
jasony0630's Avatar
76.26.106.124
damn...good luck man.
it looks like a huge cluster[freak] inside your del sol, hope everything is good.
Old Mar 16, 2008 | 06:05 PM
MrMug3n's Avatar
Default whoot whoot!!!
All is good... I AM KING!!! wipers work Windows will Work after i pick up my other drivers side switches due to blowing this one tryn to figure out the problem. just cleand up the complete inner harness and got rid of the mess the preveous owner created also had to fallow some grounds into the engine bay were cut spliced corroted and damaged.
Old Mar 16, 2008 | 06:07 PM
MrMug3n's Avatar
Default (MrMug3n)
i hate people who try to be machanics and rig things!!! Just do it the right way the first time and life will be better for everyone you Cheap bastards I cant stand cleaning up after your mess!
Old Mar 16, 2008 | 07:26 PM
jasony0630's Avatar
76.26.106.124
glad you got it working
video_voide
Feb 26, 2018 06:41 PM
gummiegorilla
Jul 30, 2009 07:32 PM
MrMug3n
Mar 15, 2008 08:08 PM
