car not working plz help
Old Mar 16, 2008 | 05:58 AM
zenon8890's Avatar
Default car not working plz help
hello, i have a 88 CRX, i checked fuel ok, spark ok, main relay clicks, engines cranks.there's no cel, but it doesnt start.
what could be the problems?!
Old Mar 16, 2008 | 06:02 AM
~sp33~'s Avatar
EFB055
Checked your timing?
Old Mar 16, 2008 | 06:22 AM
zenon8890's Avatar
i dont think so, the car was working perfectly at night, parked it and went back in the morning to go to work and its not starting anymore, the engine cranks i can tell
Old Mar 16, 2008 | 09:26 AM
twiztid17thninja's Avatar
Default Re: (zenon8890)
do you have compression?
Old Mar 16, 2008 | 09:39 AM
Former User's Avatar
Have you checked whether the timing belt is loose or broken?
Old Mar 16, 2008 | 02:23 PM
zenon8890's Avatar
i just found out, i'm not getting any signal to the injectors, i checked the injectors wiring they r fine, i changed the ecu same thing, tried my ecu into another crx, it worked fine, i found a loose wire and i start to get code 6, but i connected that wire and it went away.
how can i fix the inectors problem?!
Old Mar 16, 2008 | 11:51 PM
zenon8890's Avatar
anyone?!
Old Mar 17, 2008 | 04:35 AM
zenon8890's Avatar
just cheked again today, i have fuel pressure, i dont have pulse from the injectors. i changed the injectors resistor box and nothing happened, what else should i do
Old Mar 17, 2008 | 08:42 AM
zenon8890's Avatar
guys
Old Mar 17, 2008 | 08:50 AM
zrickety's Avatar
you may have covered this, but fuses? also check plugs at the ecu...sometimes moisture or corrosion can kill a pin. sounds like you've checked about everything tho
Rob!
Dec 15, 2005 10:03 AM
kidrolla
May 21, 2005 06:17 AM
EGHatchy
Jul 14, 2002 11:25 AM
