Header..Leak problem
Old Mar 15, 2008 | 07:08 PM
daredeezy619's Avatar
Default Header..Leak problem
Just installed a 4-2-1 Megan racing header on my car and it feels as if i loss a lot of power and can hear a leak somewhere near the bottom where it connects to the cat. Can this cause a loss of power? Or are they just shi%y headers?
Old Mar 15, 2008 | 07:26 PM
ShortyzKustomz's Avatar
A bad exhaust leak can couse a very slight loss in low end, Header on a honda changes low end a little as well
Old Mar 15, 2008 | 08:27 PM
Default Re: (ShortyzKustomz)
thanks . yeah i think the leak is coming from near the radiator in that area. i don't think that a leak near the cat would be a problem because i heard that some people run that area disconnected to gain more hp.
Old Mar 15, 2008 | 08:35 PM
crazyguy's Avatar
Default Re: Header..Leak problem (daredeezy619)
is your megan header 2 pieces or one piece design. if 2 pieces design. the gasket that goes between manifold to down pipe has blown. this is very common for megan header and what i did is i bought a exhaust material sheet from local auto parts store and cut it .it works better than megan's gasket.
Old Mar 17, 2008 | 12:43 AM
Default Re: Header..Leak problem (crazyguy)
It's a 2 piece. I bought it off some kid for 10 bucks. It originally had cracks on all 4 of the piping that connected to the engine at the top but i had it welded. I dont think that has anything to do with the loss of power but i do feel air coming out between the down pipe on one side. I probly need to tighten on of the bolts down a little more. Wish i had a compressor to make things easier. The o2 seems like it's not screwed in all the way but thats as far as i can tighten it. I don't think it has anything to do with that. But i'll try and tighten the bolt and i'll let you guys know if it fixes it. thanks!
Old Mar 18, 2008 | 12:15 AM
could a leak near the cat cause loss of power ? i don't think i used a donut. but i don't know if it can affect performance.
Old Mar 18, 2008 | 02:17 AM
monkeysauce's Avatar
I've had luck using Permatex Copper on exhaust connections in the past. You can try getting a higher quality gasket (Megan gaskets are garbage), then put a little bit of the Permatex on each side of the gasket. You can even put some around the gap once you bolt the two pieces together.
fubuallstar
Jun 12, 2008 03:41 PM
Extreez
Jan 24, 2007 03:28 PM
Racermech
Sep 23, 2006 06:55 PM
stiness101
Jan 11, 2006 10:12 AM
