my car is bogging out y????????
Old Mar 15, 2008 | 07:06 PM
vtechachey's Avatar
Default my car is bogging out y????????
ok i just put the new head on and got it running good but it's bogging know i put fuel injector cleaner and did a oil change so what can it be lmk thx
Old Mar 16, 2008 | 09:32 AM
vtechachey's Avatar
Default Re: my car is bogging out y???????? (vtechachey)
sum one ????????????
Old Mar 16, 2008 | 09:39 AM
BoSox46GSr's Avatar
You sure you put eerything back together the correc way? Double, triple check... when was the last time a tuneup was done?
Old Mar 16, 2008 | 12:11 PM
vtechachey's Avatar
i dont know i just got the car but the car was running good befor i took the head off
and it don't bogge if the car is cold
Old Mar 16, 2008 | 12:19 PM
BoSox46GSr's Avatar
Well it sounds like everything was good before... and now you pulled the head off and it bogs. Why did you swap heads??
Old Mar 16, 2008 | 04:45 PM
vtechachey's Avatar
cuz i jump timing and [freak]ed up sum **** in the head
Old Mar 16, 2008 | 05:05 PM
vtechachey's Avatar
and the distributor cap has a lil hole in it but the car was running good before with the hole in it
Old Mar 17, 2008 | 09:00 AM
vtechachey's Avatar
any one ??????
Old Mar 17, 2008 | 01:38 PM
be18see1's Avatar
maybe try adjusting your valve clearances?
Old Mar 17, 2008 | 03:20 PM
HmgLauj69's Avatar
vacuum? check the IACV
Old Mar 19, 2008 | 09:51 AM
vtechachey's Avatar
Default Re: my car is bogging out y???????? (HmgLauj69)
my car boggs if the o2 sensor it hooked up but if it's not the check engine light coms on and it runs good yyyyyyyy????
Old Mar 19, 2008 | 11:23 AM
be18see1's Avatar
dirty/bad o2 sensor. try cleaning it off first and if that doesnt work, time to buy a new one.
Old Mar 19, 2008 | 02:20 PM
vtechachey's Avatar
o ok thx
Old Mar 19, 2008 | 02:23 PM
steveharrmr23's Avatar
did the o2 sensor work for you if not let me know
Civic_07
Jun 10, 2008 04:49 PM
zoso
Mar 11, 2008 06:32 PM
redefsir
Dec 7, 2007 03:44 AM
fbw2003
10
Apr 20, 2006 05:03 PM
rpv173
Aug 2, 2005 06:08 AM
