vortech s/c ls vtec questions
i have 2000 civic si what year l/s bottom end or year range will work best for l/s vtec set up and then for no knock sensor should i run i beleive its a p30 ecm w/ hondata or please offer suggestions ! plan on using je 9.5: 1 pistons on eagle rods z10 block girdle and send head to port flow and also crower stage 2 turbo cams does this sound like an acceptable set up for a daily driven vehicle that will be some what of a weekend warrior or should i look into beefing the block w/ sleeves ? any valid input on this would be helpful thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">i would ditch the s/c and go turbo instead</TD></TR></TABLE>
and only you can determine if it can be a daily, it depends on what u can put up with
Spooled1.6L
Jul 7, 2004 04:30 AM
