92 Accord no spark
Old Mar 15, 2008 | 05:32 PM
scadams's Avatar
Default 92 Accord no spark
Driving my 92 accord down the interstate and it just shuts off. cranks but no fire.
I'm not getting any spark.
I replaced the coil, which is getting power.
Tried another ECU.
Fuel pump does turn on.
Took off cap, dis. is turning.
Whats next?!?!?
Old Mar 15, 2008 | 05:36 PM
Chiovnidca's Avatar
Default Re: 92 Accord no spark (scadams)
Is the check engine light coming on? Are there any stored trouble codes? Is the igniter switching the coil? Is the ecu sending a signal to the igniter?
Old Mar 15, 2008 | 05:57 PM
scadams's Avatar
Default Re: 92 Accord no spark (Chiovnidca)
There are no stored codes. By that, I am meaning the check engine light does not stay on.
I don't work on Honda's very much. How do you check the igniter, and where is it?
The coil has power going to it when the key is on, but none of the other ones pulse when turning it over.
Old Mar 16, 2008 | 04:43 AM
scadams's Avatar
Also checked the ground at the thermostat, looks good.
Old Mar 16, 2008 | 06:30 PM
scadams's Avatar
anyone??
Old Mar 16, 2008 | 07:13 PM
jdsmooth's Avatar
I had a similar problem, thought it could have been many things, replaced the dsitributor, and that did the trick.
Old Mar 17, 2008 | 12:43 PM
scadams's Avatar
Default Re: 92 Accord no spark (jdsmooth)
I'll try that....my parts bill is piling up...just don't want to replace things when I don't need to!
Old Mar 17, 2008 | 05:29 PM
hondadude's Avatar
if you have a test light you can do a couple simple checks, Turn on the ignition, get the coil set up so you can watch for spark to ground.
Then with the test light grounded to the block, touch the test light probe to the Blue wire connection of the ignitor,[last wire on the side] the coil should throw a spark.
That blue wire is the wire that the ECU switches the ground on to cause spark.
Okay if that didn't pan out, you can try this method; I've never done this method.
connect a test lite
1 lead to the neg side of the coil the other to any good ground,
have someone crank the engine,
if test lite pulses it is a bad COIL ..
if test lite does NOT pulse it is a bad IGNITER
Old Mar 18, 2008 | 05:28 AM
scadams's Avatar
Default Re: 92 Accord no spark (hondadude)
Replaced the Dizzy last night, that fixed it.
Old Mar 18, 2008 | 03:57 PM
jdsmooth's Avatar
Heres the problem I ran into, a mechanic pointed this out to me after the fact.
Over time, the cap on the dizzy doesnt seal properly, over time, moisture builds up in there and eventually just mucks everything up. Now everything may look okay, but the thing is with moisture is, it will eventually dissapate, leaving no trace detectable to the human eye.
Long story short, make sure your cap is sealed properly and tightened, but not too tight, you can even have just a hairline crack which will decrease the life of your entire dizzy by 50% due to residual moisture damage.
Hope this was informational.
Old Mar 19, 2008 | 07:19 AM
scadams's Avatar
I drove it this morning and the tach stop work after about thirty miles. I parked and turned the headlights off and it works...only when the lights are off. When you turn the lights back on, tach turns off!
Old Mar 19, 2008 | 11:09 AM
Antscoe's Avatar
You must have a shor somewhere.
Old Mar 19, 2008 | 01:42 PM
Chiovnidca's Avatar
Default Re: 92 Accord no spark (Antscoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Antscoe &raquo;</TD></TR><TR><TD CLASS="quote">You must have a shor somewhere.</TD></TR></TABLE>
More likely a poor ground connection.
92_Accord_LX
Nov 13, 2009 05:13 PM
banshee4
Dec 21, 2007 06:19 AM
afreeclimber
Aug 19, 2006 11:51 PM
branicvw
Aug 18, 2006 10:53 AM
groove control
Jun 1, 2004 05:58 PM
