New Clutch Problems
Old Mar 15, 2008 | 02:36 PM
syphers47's Avatar
Default New Clutch Problems
Alrite i got myself a new clutch for my 97 2.2 CL (finally the old one had about 176xxx miles on it.) I got an exedy clutch and pressure plate, a 10lb flywheel and new throwout bearing. Its got about 180 miles on it right now the only problem I have is a rattling sound coming from my clutch fork, which started around 70miles. It rattles when i'm idling or when the car is in gear and the rpms are low. If I push the clutch in just a hair it'll go away. Every now and then it wont rattle but it does most of the time.
Soooo what i'm thinking is:
1> the pedal needs to be adjusted to get rid of any play
2>I didnt bleed the clutch fluid correctly and there could still be an air bubble in the line
3>the slave cylinder is going and not holding the fork tightly enough
4>the throw out bearing is loose or bad
5>the cap on my clutch fluid resevour (cant spell) does leak and that could prevent the system from building up enough pressure-- doubt this though.
thats all i can think of. I havent beat on the clutch at all. I did have a few shakey starts and two stalls when i first started driving it. I'm hoping nothing rattled out of place. I dont think the throw out bearing is bad because its not a clicking noise just a rattling like a bad tensioner on a chevy or something. And the slave cylinder is 10 years old just something to consider. I was just wondering what you thought. Thanks Guys!
Old Mar 15, 2008 | 04:37 PM
hondadude's Avatar
Default Re: New Clutch Problems (syphers47)
Is the clutch arm snapped back onto the pivot ball stud in the bell housing?
It is supposed to be held on by a spring clip retainer.
You don't want the slave pushing tight against the fork, that would be the same as riding the clutch al the time.
Old Mar 16, 2008 | 10:14 AM
syphers47's Avatar
honestly i didnt even remove the clutch fork i just left it in place. so its probally a bad TOB..right?? could anything else to a fault???
Old Apr 27, 2009 | 10:02 PM
Boost it's Avatar
putting grease behind the fork on the ball...
Old Apr 28, 2009 | 11:04 AM
notAdiesel's Avatar
that's weird, my car did the same thing when the clutch was shot. the mechanic put a new one and i haven't heard it since
bacarter1
Mar 15, 2014 03:06 AM
MrMug3n
Honda Civic (2001 - 2005)
Jun 26, 2011 12:01 AM
s13hero
14
Nov 21, 2010 04:57 PM
JFG Kevin
Apr 12, 2006 01:56 AM
FK00GSR
Mar 31, 2005 06:55 AM
