koni yellow with skunk2 lowering spring 2.5" race
Old Mar 15, 2008 | 02:34 PM
milanored92h22's Avatar
Default koni yellow with skunk2 lowering spring 2.5" race
What do you think about it?
Old Mar 16, 2008 | 10:53 AM
OPTIMUS_PRelude's Avatar
Default Re: koni yellow with skunk2 lowering spring 2.5" race (milanored92h22)
my car sits on 2.5" drop..H&R race..it's my daily it rides incredible..it's low, you just gotta be extra careful
Old Mar 16, 2008 | 02:07 PM
snobordboy's Avatar
Moderator
yeah I run Koni Yellows with Neuspeed race, its also about a 2.25-2.5 inch drop spring, and it is verrrry low, I have to drive very carefully alot of places. I also have my perches on the shocks set at the lowest up front and one up on the back though, so I could raise it a bit, which I will probably do when I get around to it, and can walk again!
Old Mar 16, 2008 | 03:38 PM
Presently I run skunk2 lowering spring 2.5 race with stock shock. Many people use H&R spring with koni yellow why? Does is better than skunk2 with koni yellow? Please send me your setup. Thank
Old Mar 16, 2008 | 06:27 PM
Default Re: (milanored92h22)
tokico HP struts / HR Race springs..smooth, stiff ride..I also have strut bars and tie bars, I dunno if that helps it to the point where it makes a difference, regardless, I love this setup and would never change..everyone has their own preferences tho..
Old Mar 26, 2008 | 02:46 PM
Default Re: (OPTIMUS_PRelude)
Others??
Old Mar 26, 2008 | 08:13 PM
TheWalrus's Avatar
go with H&R race with koni yellows, i have these and its sweet, takes offramps like a ****
skunk2 with konis will work just fine...but imo the HR setup will handle better, i think the springrate is perfect for the street
Old Mar 27, 2008 | 03:50 PM
Default Re: (TheWalrus)
Tanks! Does the spring rate are more higher on my skunk2? I find informatin but I never see information on it! (it's a 2.5 inch drop not the 1.5)
Modified by milanored92h22 at 5:01 PM 3/27/2008
Dxs
Suspension & Brakes
Sep 2, 2007 05:22 PM
pubes2942
Suspension & Brakes
Jan 2, 2007 11:09 AM
hi-Powered
Suspension & Brakes
Dec 29, 2005 12:01 AM
DA_TEG
May 2, 2004 01:29 PM
Tweakmeister
Jan 2, 2003 08:46 PM
