Suspension & Brakes Theory, alignment, spring rates....
EG and EK GC coilovers
Old Mar 14, 2008 | 11:18 PM
iNERtIA's Avatar
Default EG and EK GC coilovers
i just installed a GC coilover sleeves on my EK w/ koni yellows. the set-up was meant for EG, is there a difference between the ek and eg GC's?
i have the sleeves maxed to the highest position and the ride height is still pretty low.
Old Mar 15, 2008 | 11:05 AM
bmoua's Avatar
are the Ground Controls koni specific? the eg and ek setup are basically identical, did you make sure you put the right sleeves onto the right sides? I've made the mistake of putting the rear coilover sleeves in the front and front coilover sleeves in the rear.
did you use washers to fit the rear koni shocks? I hope you did, if not do it
Old Mar 15, 2008 | 08:55 PM
egsleepercivic's Avatar
how tall are the springs 8inch 7inch...?
Old Mar 15, 2008 | 09:56 PM
iNERtIA's Avatar
koni specific. im pretty sure i had em right. and yeah i have the washers for the LCA. as far as the spring height im not sure. do they make different length sleeves and springs?
Clayton
37
Sep 16, 2011 02:33 AM
turnsignalandy
Suspension & Brakes
May 5, 2008 05:11 PM
jordanl250
May 4, 2007 10:10 PM
EK FLY
Aug 16, 2006 05:46 PM
92JDMSiR
Feb 10, 2003 12:07 PM
