Possible Input shaft bearing problem?
Old Mar 14, 2008 | 11:01 PM
TOO MUCH TORQUE's Avatar
Default Possible Input shaft bearing problem?
what kind of noise does a bad ISB make?
well, on my teg, i hear this bird like chirping noise when its idling. When i put very little pressure on my clutch pedal, it goes away. When i take my foot off the clutch the noise comes back a few seconds later. car drives fine and there isnt any sort of rumbling noises.
i asked my cousin who is a mechanic and he thought it was a old belt causing the noise, but i didnt tell him it goes away when i press the clutch. is there any belts for the tranny?
Old Mar 15, 2008 | 06:12 AM
hatchling37's Avatar
Default Re: Possible Input shaft bearing problem? (TOO MUCH TORQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote"> is there any belts for the tranny?</TD></TR></TABLE>Hahaha! No, there is not.
Bird-like chirping is most definitely some bearing, but not an ISB. It's more of a muffled growling. Have you checked your pulleys? Put a stethoscope on them before you go tearing your tranny off there.
Old Mar 15, 2008 | 08:50 AM
Default Re: Possible Input shaft bearing problem? (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Hahaha! No, there is not.
Bird-like chirping is most definitely some bearing, but not an ISB. It's more of a muffled growling. Have you checked your pulleys? Put a stethoscope on them before you go tearing your tranny off there.</TD></TR></TABLE>
thats good to hear, but why would the bird like chirping noise go away when i put a little pressure on the clutch?
Old Mar 15, 2008 | 09:19 AM
HeikDiesel's Avatar
thats good to hear, but why would the bird like chirping noise go away when i put a little pressure on the clutch?</TD></TR></TABLE>
throw out bearing
Old Mar 15, 2010 | 08:38 AM
b16_swap's Avatar
throw out bearing
I also have the same problem on my civic... but it happened after I got my clutch replaced by a shop, they also replaced the throwout bearing, so the only other thing it could be is my pulleys and belts, just get a 60k service and your good :p
Old Mar 15, 2010 | 07:06 PM
Atomic1's Avatar
I had the exact same noise and symptoms. Very light pressure on the clutch would make the noise go away. I dropped the transmission and found the throwout bearing races to be loose. Replaced the throwout and clutch (while I was there). Left the pilot bearing alone. Noise has been gone for 40,000 miles now.
Vt3c_eg
Apr 28, 2008 11:31 AM
lurkin' eg
Oct 2, 2007 06:36 PM
ch0g0nda
18
Jul 19, 2007 06:34 AM
jimbrown
Jul 17, 2007 12:35 PM
4gnhatch
Jun 24, 2005 06:53 PM
