why dont people make intake manifold, that are like a turbo manifolds?
Old Mar 14, 2008 | 09:59 PM
mkw1's Avatar
Default why dont people make intake manifold, that are like a turbo manifolds?
would a intake manifold that would be made like a turbo exhaust manifold but reversed flow better? so you would put a tb to a 1 to 4 collector with tubes going to the head (kind of like a top mount turbo manifold mounted on the intake side is with a tb where the turbo would go) flow better then a big open space with ports coming of in a different direction than the direction of flow? just a thought i had, sorry if this is a stupid question.
Old Mar 15, 2008 | 12:09 AM
RC000E's Avatar
Default Re: why dont people make intake manifold, that are like a turbo manifolds? (mkw1)
The perfect aerodynamic shape is a teardrop. Air coming and going likes different shapes is the point. Not to mention doing an equal length intake mani leads to extremely long intake runners, poor cylinder distribution, along with some other arguements that exist. It's been done by GM and some others actually...and wasn't too successful.
Old Mar 15, 2008 | 09:05 AM
.john.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkw1 &raquo;</TD></TR><TR><TD CLASS="quote">would a intake manifold that would be made like a turbo exhaust manifold but reversed flow better? so you would put a tb to a 1 to 4 collector with tubes going to the head (kind of like a top mount turbo manifold mounted on the intake side is with a tb where the turbo would go) flow better then a big open space with ports coming of in a different direction than the direction of flow? just a thought i had, sorry if this is a stupid question.</TD></TR></TABLE>
honda has done it before... remember dual point injection? and most never d series single cams have a center mounted throttle body that just splits to 4 runners.
also the conventional "collector" doesnt flow well backwards like how you are saying. air flows better over curves instead of the sharp edges of the inside of a collector run backwards.
Old Mar 15, 2008 | 10:10 AM
92TypeR's Avatar
FSAE
All of the articles and texts I've read about intake tuning talk mainly about the relationship between runner length and diameter versus plenum volume and shape. There are other additional features of a good (or bad) intake, like sharp edged orifice (vena contracta) and bellmouth designs, but most of the power you make, and where you make it, is determed by runners and plenum working together. With a "tubular" style intake system, you eliminate the ability to properly tune an intake.
Old Mar 15, 2008 | 10:19 AM
mkw1's Avatar
Default Re: why dont people make intake manifold, that are like a turbo manifolds? (92TypeR)
good info, this makes more sense now
Old Mar 15, 2008 | 10:24 AM
GTibunny16v's Avatar
Toyota had one on their Corolla
Old Mar 15, 2008 | 12:21 PM
antireversion's Avatar
you end up with pretty long runners and no plenum... end result would be an intake that made peak power just off idle..l0l (exageration of course) but you get the idea..
Old Mar 15, 2008 | 02:08 PM
Bailhatch's Avatar
Default Re: (antireversion)
we have some aluminum IMs at work that are configured like that...I think they are from a GM 4 cyl. runners are about 14" long and about 1.5" ID
Old Mar 15, 2008 | 04:41 PM
rorik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">most of the power you make, and where you make it, is determed by runners and plenum working together. With a "tubular" style intake system, you eliminate the ability to properly tune an intake.</TD></TR></TABLE>
What about the plenum and the intake tube leading to it? The intake tube itself has a big effect also. With a "plenumless", for lack of a better word, IM, you can still tune it by varying the runner length and diameter, and the same with the tube leading to it. I think the big plenum is necessary with runners perpendicular to it, to drop the velocity across them at high rpm, but not with a manifold with runners in line with the plenum. ?
I still think that a manifold with a decent radius inlet into each runner will flow a hell of a lot better in that direction that a merge collector though. I have seen some manifolds that look almost like a header in reverse, but have no idea how they performed. Subarus have almost no plenum volume compared to a normal IM, but they don't have the merge collector in reverse.
Old Mar 15, 2008 | 04:53 PM
RC000E's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">we have some aluminum IMs at work that are configured like that...I think they are from a GM 4 cyl. runners are about 14" long and about 1.5" ID</TD></TR></TABLE>
Yep...the Quad 4's in the H.O. (high output) Cutlass Calais had them. They had about the worst throttle response ever. 160hp was "H.O." in GM's mind
Old Mar 15, 2008 | 05:12 PM
Bailhatch's Avatar
Default Re: (RC000E)
Yes, that's exactly what motor it was, the name escaped me. Before I worked here they put one in an Anglia with a supercharger. He wants a turbo ecotec now
Old Mar 15, 2008 | 05:21 PM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">
Yep...the Quad 4's in the H.O. (high output) Cutlass Calais had them. They had about the worst throttle response ever. 160hp was "H.O." in GM's mind</TD></TR></TABLE>
opposed to the 170hp honda engines produced back then?
Old Mar 16, 2008 | 02:34 PM
dmotoguy's Avatar
Default Re: (E-Rok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Rok &raquo;</TD></TR><TR><TD CLASS="quote">
opposed to the 170hp honda engines produced back then?</TD></TR></TABLE>
cutlass probably weighed 3700+ lbs... lol
Old Mar 16, 2008 | 02:58 PM
RC000E's Avatar
Default Re: (E-Rok)
160hp out of 2.3L Quad 4's versus 160 out of B16 Honda's...yeah
Old Mar 17, 2008 | 08:58 AM
G2turbo_terror's Avatar
I've sen these on later 90's (8th gen?) mitsu galants w/the 4g64. If I remember correctly, they look like a "side winder" exhaust manifold. Very long runners.
Old Mar 18, 2008 | 06:35 PM
manifoldmiketyson's Avatar
Default Re: (G2turbo_terror)
220whp on 10psi stock motor. i built it about a year ago
Old Mar 20, 2008 | 04:33 PM
fusion210's Avatar
Actually, they had a 185hp and 190hp version.
http://en.wikipedia.org/wiki/O...-1991
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">
cutlass probably weighed 3700+ lbs... lol</TD></TR></TABLE>
From edmunds.com Curb Weight: 2823 lbs.
"Motor Trend's test of a W41 yielded a 14.7 @ 95.7 mph quarter mile time. "
from http://www.442.com/vcs/1973_pres/smalley.html
Much faster than motor trend's ITR test: Quarter mile, sec/mph 15.3/93.4 from http://www.motortrend.com/road....html
Pretty cool for their day.
Old Mar 20, 2008 | 06:20 PM
Default Re: why dont people make intake manifold, that are like a turbo manifolds? (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">The perfect aerodynamic shape is a teardrop. </TD></TR></TABLE>
Whats perfect about a tear drop ?? what part of an intake is shaped like a tear drop ? just curious
Old Mar 20, 2008 | 06:59 PM
Kevin's Avatar
Default Re: why dont people make intake manifold, that are like a turbo manifolds? (antireversion)
Old Mar 20, 2008 | 11:34 PM
92TypeR's Avatar
FSAE
Default Re: why dont people make intake manifold, that are like a turbo manifolds? (Kevin)
That picture is decieving.
I've seen that motor before, and it feeds into an aluminum plenum/airbox and into four runners for each bank. The runner shape looks very similar to that of the cast JG intakes for 350/small block chevy engines.
Old Mar 21, 2008 | 02:57 AM
Kevin's Avatar
You can see that he used an off the shelf lower plenum but the runners are similar to an exhaust manifold like the op stated.
What is a JG intake manifold for small blocks? Do you mean Edelbrock?
Old Mar 21, 2008 | 06:19 AM
thats a quad turbo contraption from Mike Moran... very long ago... definately not one of his most successful attempts
Old Mar 21, 2008 | 07:44 AM
honduh_head's Avatar
why not have equal runners go to a overly large TB, like a 120 mm off a mustang or something? especially if you are boosted? how could a plenum be useful under 45 psi of boost?
really cool thread btw &lt;-- to the OP
Old Aug 5, 2008 | 04:34 AM
ChevelleSSLS6's Avatar
If something goes wrong with that engine, do you call a plumber or a mechanic?
Anyway, 160hp out of a 4banger in the early 1990s when GM made the Quad4 HO it was pretty powerful for the day. If I remember right the cylinder head had some pretty big ports which killed the velocity of the gases (intake and or exhaust, I don't really remember) and the lack of velocity killed torque. This is partially why Honda uses tiny exhaust pipes on 1.6L civics, to promote exhaust gas velocity which translates into better exhaust scavenging and finally a little more torque. Not that Honda anything in a car is a torque monster, they're built to rev.
Old Aug 5, 2008 | 07:23 PM
Boostedld9's Avatar
Default Re: why dont people make intake manifold, that are like a turbo manifolds? (ChevelleSSLS6)
heres the gm 2.3 intake manifold
i swapped it for this piece
