fs/ft honda cbr954 itb's and modified y8 intake manifold
for sale or trade is a set of itb's from a honda cbr 954
the 954's stock injectors are 240cc and have multiple hole instead of one hole/needle and have obd2 injector plugs
they also have compatible map and tps sensors
you can also use the 954's fuel rail
other honda car injectors are a easy install
the Y8 manifold was modified by adding small sections of aluminum tube to mount the itb's
for brake master vacuum i welded npt threaded bungs into the old injector holes
and installed 3/8 barbed hose adapters
i also welded a smaller pipe on to where the coolant line came out of the manifold cause the original interfered with the tubing i welded on for the itb's
i hope this description is good enough cause i cant find my patch cord to get the pics from my camera but when i do find it i will post pics
dont really know a asking price but i payed $150 for the throttles
and have a good amount of time in the manifold
but i am mainly interested in making my auto 96 civic ex manual
so i really need
sohc ex hydro trans
sohc flywheel
sohc clutch
96-00 civic clutch lines
96-00 civic manual pedal assembly
96-00 civic clutch master cylinder
96-98 civic ex ecu or obd2a to obd1 harness w/p28,p05,or p06
92-00 civic shift linkage w/ shifter
92-00 civic clutch slave cylinder
lower tranny mount and REAR TRANNY MOUNT off of a manual 96-00 civic
manual starter
and a manual y8 intake manifold
im pretty sure no one will have all this stuff nor if they did give me all of it for what i have but any good amount of it would be greatly appreciated
lmk!!
so i really need
sohc ex hydro trans
sohc flywheel
sohc clutch
manual starter
lmk!!
Bump I'd like to see some pics as well.
I have a y8 manifold for ya, too.
(tip. take your camera's memory card to WalMart or something and get the pics put onto a CD, then you can have them on your PC.)
jdmf23accord
14
Dec 16, 2010 04:55 AM
pornstarSR
33
Nov 24, 2009 10:54 AM
Civiclx
Jun 19, 2004 04:15 PM
