Classic Hondas All Pre-1988 Hondas.
87 crx zc swaping to obd 1
Old Mar 14, 2008 | 01:51 PM
usdmblackcivic's Avatar
Default 87 crx zc swaping to obd 1
i have a 87 crx with a zc swap turbo.im tryin to swap it to obd 1 so i can get her tunned. i need help bad cuzz no one in my are will help me out.they say it to much work.. any one do this befor?
Old Mar 15, 2008 | 07:15 AM
anyone?
Old Mar 15, 2008 | 07:56 AM
rextec's Avatar
Default Re: (usdmblackcivic)
i did this. you need to get yourself a manual for the car you own and then a manual for a 1988-1991 civic/crx. convert your wiring to the same specs as the 88-91 civic/crx and buy a obd0-obd1 adapter harness for the ecu side. this way everything stays in order and you can track down electrical problems. this is the way i did mine and i now have a built and turboed d16z6 in my 86 crx si with zero electrical problems and no CEL. hope this helped, good luck!
heres a link to my write up which may help you. also if your not a part of red pepper racing join it!!
http://www.redpepperracing.com...20487
Old Mar 15, 2008 | 04:02 PM
Default Re: (rextec)
thanks il check it out..
Mike_Brescia
Jan 18, 2016 08:50 AM
hondakevin21
Jul 30, 2006 10:36 AM
daigo
Feb 8, 2005 07:19 PM
