New Dyno Vid * EXPLODE* jareds ITR
Old Mar 14, 2008 | 12:27 PM
00-501itrspec's Avatar
Default New Dyno Vid * EXPLODE* jareds ITR
heres a short teaser clip from last nights dynop session ,
we are tuning my Spray , and blew up the car ( short version of this story )
we havent opened up theh motor yet so its Iffy , but prob ( hopefully a headgasket )
this vid isnt when we blew up , just was the first spray we gave to her , and she coughed a little bit ,
it looks like a turbo dump tube , not an intake
comments always welcome
http://youtube.com/watch?v=GidNxoIE-xY
****************EDIT ***********
Here is a dyno video ( full pass)
made 312 hp , and 276 tq , if i remember correctly , on a small shot , ( 80 -100 hp jets, Roughly )
enjoy
http://www.youtube.com/watch?v...lated
Modified by 00-501itrspec at 5:53 PM 3/14/2008
Modified by 00-501itrspec at 11:51 PM 3/15/2008
Old Mar 14, 2008 | 12:36 PM
white rocket's Avatar
Default Re: New Dyno Vid * EXPLODE* jareds ITR (00-501itrspec)
That was cool
Old Mar 14, 2008 | 01:24 PM
JjuuN R's Avatar
Default Re: New Dyno Vid * EXPLODE* jareds ITR (white rocket)
Kay...
Old Mar 14, 2008 | 01:41 PM
citrus3000psi's Avatar
I want to see the other vid...
I take it this is a dry kit?
Old Mar 14, 2008 | 01:48 PM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (citrus3000psi)
caughed a bit??? I hate the nitrous. I blew up my old car on the dyno spraying. Boo to the nitrous......Boo.
Old Mar 14, 2008 | 01:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">I want to see the other vid...
I take it this is a dry kit?</TD></TR></TABLE>
not a chance , direct port
my 2 friends filmed it from the front corners , so when they post it ill link it
Modified by 00-501itrspec at 7:02 PM 3/14/2008
Old Mar 14, 2008 | 02:31 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">That was cool </TD></TR></TABLE>
Remember folks, nitrous backfire is a bad thing. It blows engines.
Old Mar 14, 2008 | 05:18 PM
Kidloco51's Avatar
Default Re: New Dyno Vid * EXPLODE* jareds ITR (neo_)
Nitrous on ITR's makes me sad.
Old Mar 14, 2008 | 05:43 PM
Default Re: New Dyno Vid * EXPLODE* jareds ITR (Kidloco51)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidloco51 &raquo;</TD></TR><TR><TD CLASS="quote">Nitrous on ITR's makes me sad. </TD></TR></TABLE>
makes me laugh
its not a dumb setup for spray tho ,
i wouldnt spray a motor that wasntt built for it , my motor is fully built , with nitrous in mind when we built it .
it is costly as well , and i only spray using C-16, so it is really expensive , the nitrous is for when i go to the 1/4 mile track , and i only use C-16 at the track . so it dosent get sprayed ALL the time as one may think .
if i cracked any pistons im most likley going to drop my compression ratio from 11.7:1 ( with a VERY decked block , comp is prob around 12:1 )
down to 9.5:1 , and toss a snail on it , that is a possibility as well .
I need to see whats going on inside my motor before i mske ANY descisions at all .
Old Mar 14, 2008 | 06:48 PM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-501itrspec &raquo;</TD></TR><TR><TD CLASS="quote">
makes me laugh
I need to see whats going on inside my motor before i mske ANY descisions at all .</TD></TR></TABLE>
Cracked sleeve?
Old Mar 14, 2008 | 08:27 PM
vivid 02's Avatar
How fast is it on the bottle ???
Old Mar 14, 2008 | 08:51 PM
volcom40street2's Avatar
Default Re: New Dyno Vid * EXPLODE* jareds ITR (vivid 02)
My travels with spray I always thought you had to get the rpms up before you mesh the pedal. To me sounded like the guy in the car was at 1000-2000 rpm when he squeezed or is it on the throttle?......Yikes that's a recipe for a blown motor.
I never hit full throttle/button unless i was above at least 4000 rpm.
Old Mar 14, 2008 | 10:30 PM
Default Re: New Dyno Vid * EXPLODE* jareds ITR (volcom40street2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">
Cracked sleeve? </TD></TR></TABLE>
nah prob not , but who knows , when we look ill let ya know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivid 02 &raquo;</TD></TR><TR><TD CLASS="quote">How fast is it on the bottle ???</TD></TR></TABLE>
hasnt been on the track built or on spray , stock time was 14.7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volcom40street2 &raquo;</TD></TR><TR><TD CLASS="quote">My travels with spray I always thought you had to get the rpms up before you mesh the pedal. To me sounded like the guy in the car was at 1000-2000 rpm when he squeezed or is it on the throttle?......Yikes that's a recipe for a blown motor.
I never hit full throttle/button unless i was above at least 4000 rpm.</TD></TR></TABLE>
NO WAY it was higher than that !!
it was around 3500-4000 rpm , and yes ur right u should have RPM up somewhat
i have a headertech 3 inch header with a 3inch flex pipe to a thermal 3 inch exhaust , and there is a few small minor leaks in the whole system , its relly loud , it sounded low to me as well so i looked on a few runs , all were around 3500 and up
Old Mar 14, 2008 | 11:44 PM
Doostur's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidloco51 &raquo;</TD></TR><TR><TD CLASS="quote">Nitrous on ITR's makes me happy! </TD></TR></TABLE>
Old Mar 15, 2008 | 01:28 AM
Stealthycivicsi's Avatar
Default Re: New Dyno Vid * EXPLODE* jareds ITR (Doostur)
You should get two of the BIG BOTTLES, that'll make it fasteR.
Old Mar 15, 2008 | 01:35 AM
Default Re: New Dyno Vid * EXPLODE* jareds ITR (Stealthycivicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealthycivicsi &raquo;</TD></TR><TR><TD CLASS="quote">You should get two of the BIG BOTTLES, that'll make it fasteR. </TD></TR></TABLE>
did you see the 20 LB one ? its huge , it would HVE to go sideways in the trunk , or the whole backseat
Modified by 00-501itrspec at 2:30 PM 3/15/2008
Old Mar 15, 2008 | 07:48 PM
enjoy
Old Mar 16, 2008 | 05:20 PM
Black R's Avatar
25 Year Member
haha, did you beat that top level evo tho?
Old Mar 17, 2008 | 02:56 PM
Big Phat R's Avatar
weeeeeeeeeeee
Old Mar 17, 2008 | 04:24 PM
Old Mar 18, 2008 | 08:31 AM
im actually only thinking of keeping spray for my new intercooler coming soon
10secivic
Sep 1, 2008 06:19 PM
Kings Performance
Aug 25, 2007 04:03 PM
98itr0448
Jul 5, 2004 03:08 PM
kruthles
Nov 3, 2003 09:36 AM
