Misfire Issue (Frustrated)
Old Mar 14, 2008 | 11:35 AM
96 EX's Avatar
Default Misfire Issue (Frustrated)
Alirght so Ive had this problem for awhile since the swap. I got a d16y8 and its throwing misfires through different cylinders and then randomly misfire. Then occasionally the cel will start flashing and my car losing all power and almost bogs down. I changed my plugs,wires,cap n rotor, and all that stuff an it still happens. The weird thing is sometimes my check engine light will be on and other times it will go off for say 3-4 days. Maybe my timing is off? any help would be apprechiated. Thanks
Old Mar 14, 2008 | 11:38 AM
crazyguy's Avatar
Default Re: Misfire Issue (96 EX)
yeah check your timing and also your fuel injectors.
Old Mar 14, 2008 | 11:45 AM
96 EX's Avatar
Default Re: Misfire Issue (crazyguy)
Alright thanks for the advice. Tomorow Im going to tear into this ***** and figure it out.
Old Mar 14, 2008 | 12:14 PM
Former User's Avatar
If the timing and fuel injectors are fine, then you also might want to consider a clogged fuel filter or faulty fuel pump.
Old Mar 14, 2008 | 02:30 PM
syawedis's Avatar
From: Fremont, california, united states of america
If your CEL is on, and your car is indeed a 96ex with an OBDII ecu. Pull the codes from the ECU. see if the misfire is isolated to a single cyl and start from there.
Old Mar 14, 2008 | 09:04 PM
EkFG's Avatar
check your dizzy and make sure the plugs are gap right. also check ohms on wire's.
Old Mar 16, 2008 | 02:02 PM
96 EX's Avatar
Default Re: (EkFG)
I pulled the cel and it said misfire on certain cylinders (1,3,4,2) in no particular order then it threw a random misfire as well. I know the wires and what not are right. Reading up on how to check the timing now since I'm only 19 and teaching myself.
Old Jul 3, 2008 | 04:55 PM
boynblue's Avatar
My Wife's 98 civic is doing the same thing. I had the distributor cap, coil, fuel filter, and plugs changed. Plug wires are new to. It got better than after a week it is back doing it again. Its misfiring randomly on all heads. What else do I need to look at to replace or clean?
Old Jul 3, 2008 | 05:03 PM
oneslow4dr's Avatar
Default Re: Misfire Issue (boynblue)
change your fuel filter then check your fuel pressure then put a noid light on your injectors and see if there pulating and if all thats fine and your sure the new parts u put on are good then its gonna be your distributor....
Old Jul 3, 2008 | 05:13 PM
boynblue's Avatar
Default Re: Misfire Issue (oneslow4dr)
Fuel filter and distributor have been changed. I have been reading archives for awhile. Looks like a guy had this same issue and changed out the knock sensor and it fixed it. Thanks for the info. Going to change out the sensor and see what that does
Old Jul 3, 2008 | 05:23 PM
lluks_844's Avatar
how about a vlave adjustment. My friends car did the same thing after. adjusted them again and problem solved.
Old Jul 3, 2008 | 05:32 PM
boynblue's Avatar
Also need to clean the vtec soleinoid.
Old Jul 3, 2008 | 05:33 PM
boynblue's Avatar
Default Re: Misfire Issue (lluks_844)
Ok thanks I will adjust the valves too.
anterman
Honda Civic (2001 - 2005)
Apr 12, 2016 05:33 AM
MidnightGSR591
Sep 12, 2011 11:47 AM
MeCrObS
10
Sep 2, 2011 03:55 AM
Jdog906
Jun 13, 2009 07:24 AM
civic89si666
Apr 13, 2006 10:00 AM
