85k on oil pump. Need to replace or not worry about it?
Old Mar 14, 2008 | 11:03 AM
totsie7944's Avatar
Default 85k on oil pump. Need to replace or not worry about it?
So I've read some articles on 'rebuilding' them, but I honestly don't have the know-how to properly check clearances if I start taking it apart. I really am tapped out on money with the whole engine re-build process and dropping another $150 is kinda making me sick to think about.
With 85k on the oil pump, I read a lot of peoples responses to prior threads in the ITR forum saying 'It should be fine, just bolt back up and go' and that they usually wouldn't replace until like 150,000 miles.
Thoughts? I'm getting a 84x89 bore and stroke, Darton sleeves, MID kit, etc, am I cool to just bolt up the oil pump as it came off?
Old Mar 14, 2008 | 11:13 AM
gsober's Avatar
not what you want to hear but it is cheap insurance for 150 bucks. plus, the motor is already apart.
Old Mar 14, 2008 | 11:20 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: 85k on oil pump. Need to replace or not worry about it? (totsie7944)
Its listed at $98.36 from Len and you get a HT discount so i would spend the few dollars for peace of mind. No sense in doing all that work and then half-assing an oil pump.
Old Mar 14, 2008 | 11:25 AM
white rocket's Avatar
I'd replace it for sure. Why would you skimp out on a ~$100 part that could be the demise of your ~$5000+ motor?
Old Mar 14, 2008 | 12:00 PM
citrus3000psi's Avatar
Default Re: 85k on oil pump. Need to replace or not worry about it? (white rocket)
You can afford to sleeve the block but cant afford an oil pump?
Thats like using kong dong on your local hookers but forgetting the lube.
Give yourself the piece of mind and get the oem pump...
Old Mar 14, 2008 | 12:15 PM
nholmes's Avatar
Default Re: 85k on oil pump. Need to replace or not worry about it? (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">You can afford to sleeve the block but cant afford an oil pump?
Thats like using kong dong on your local hookers but forgetting the lube.</TD></TR></TABLE>
lol that's sig worthy right there.
Might as well do the water pump too while you're in there.
Old Mar 14, 2008 | 12:37 PM
Mugen Mike's Avatar
Oh t00tsie.... :sigh:
Old Mar 14, 2008 | 12:46 PM
len's Avatar
len
Default Re: 85k on oil pump. Need to replace or not worry about it? (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">Oh t00tsie.... :sigh:</TD></TR></TABLE>
This thread is overwhelming.
"Kong Dong"
"Lube"
"tootsie"
Old Mar 14, 2008 | 01:16 PM
KOALA YUMMIES's Avatar
Default Re: 85k on oil pump. Need to replace or not worry about it? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
"Kong Dong"
"Lube"
"tootsie" </TD></TR></TABLE>
Yeah I was wondering when youd find this, you must be excited!
Old Mar 14, 2008 | 01:52 PM
Default Re: 85k on oil pump. Need to replace or not worry about it? (KOALA YUMMIES)
"Kong Dong"
"Lube"
plus the "plug" I put in for Len....it was bound to happen
Old Mar 14, 2008 | 02:57 PM
totsie7944's Avatar
Default Re: 85k on oil pump. Need to replace or not worry about it? (attentionwhore)
lol you guys are funny. Already got a new water pump. Guess I'm getting a new oil pump. Len add it to the other shipment you send... haha
Old Mar 14, 2008 | 05:26 PM
JOHN WAYNE's Avatar
wat?
the171
Engine Machining & Assembly
11
Jul 14, 2016 09:05 AM
Mr. Future
Nov 22, 2015 07:46 PM
92integraVTECgsr
Jan 28, 2007 08:25 PM
johng
Mar 30, 2006 06:53 AM
Lei Siew Long
Apr 17, 2002 08:54 PM
