I hear a clicking noise
iu hear a clicking noise (front drivers side) i dont think its the axle. I think is something with suspension. do i nees to replace my shock? if im in 2nd gear at 4k rpms and stomp the gas and let off it will click.
its not the valves,its when im going straight and the only reason it does it at that rpm is because that when i have the power to do it and thats when i was checking it out. is it a tie rod maybe
its a clunk noise and it wasnt happening until i jacked my car up on that side. i let it down after tensioning an ac belt and now i hear this noise. im putting coilover sleeves and springs from eibach and GC on tonight if i get time so i will investigate more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai »</TD></TR><TR><TD CLASS="quote">Could be a ball joint gone bad.</TD></TR></TABLE>
+1
Or popped out when you jacked it up and did go back in correctly?
+1
Loud squeaking noise, sometimes turns to knocking is this messing up anything untill I get it fixed?
samuraijackass
Nov 25, 2004 08:21 PM
