Need some opinions on a Decision
Old Jul 8, 2002 | 10:03 AM
insnimprtguy's Avatar
Default Need some opinions on a Decision
k, as some of u might know i'm building up an LS/Vtec
now i'm looking at something like this for my set up...
Bullfrog/GUDE Racing Package:
Ported and polished cylinder head, racing valve grind, ported intake manifold, high velocity throttle body, tuned ECU, and cams
Full Skunk2 Valvetrain:
Springs, Retainers, and Valves(high compression)
JE Pistons and Eagle Rods (compression around 11.5-12)
Spoon Headgasket(maybe) and Thermostat
(I also intend to put my ACT 2600 in at the same time)
i'm curious for some opinions...
should i:
a.) get some better cams? if so, which is the best for a B18C? and still holding a good idle if possible
b.) add some "juice" w/ the NOS Plate System? if so, what all do i need to run it safely and smartly?
c.) any opinions of next best mod? ($ around 500-800)
FYI-i'm looking for an NA/AM getting around 210-230 whp (w/out nitrous), and if i add nitrous around a 100-150 shot safely, and i have lots of mods already, if needed i'll list them when asked
thanx again,
Jay
Old Jul 8, 2002 | 12:22 PM
neo1z's Avatar
Default Re: Need some opinions on a Decision (insnimprtguy)
high compression is not good with nitrous. especially 11.8 or whatever you said.
ESPECIALLY not a 100 shot. high compression and nitrous = detonation.
detonation = see ya new lsvtec.
id avoid nitrous in your case.
in terms of the cams...skunk stage 2 sounds great for you...if youre going pure race go stage 3, but you have a great setup coming.
bertsb18hatch
Sep 15, 2009 08:41 PM
ctr-ek
May 4, 2009 06:35 PM
4ghatch
Mar 29, 2007 05:44 AM
methodz55
Mar 9, 2005 05:36 PM
NirVTEC
Feb 17, 2004 10:38 AM
