ITR stock lowering springs, which is which (front and rear).
Old Mar 14, 2008 | 08:40 AM
92integraVTECgsr's Avatar
Default ITR stock lowering springs, which is which (front and rear).
Which spring is the Front and which is the lower? I thought the longer one is the rear and the shorter one is the front.
can you guys confirm that?
Old Mar 14, 2008 | 08:42 AM
BlueR's Avatar
Default Re: ITR stock lowering springs, which is which (front and rear). (92integraVTECgsr)
confirmed
Old Mar 14, 2008 | 09:33 AM
CW-ITR's Avatar
Default Re: ITR stock lowering springs, which is which (BlueR)
Hmm...For some reason, I think the long one is for the front and the short one is for the rear. I'll double check tonight when I get home.
Old Mar 14, 2008 | 11:26 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: ITR stock lowering springs, which is which (CW-ITR)
How dare you question Marc!
Old Mar 15, 2008 | 06:38 AM
GreedyPT's Avatar
Short=front
Long=rear
You can confirm that by checking the bottom of the spring.
Old Mar 16, 2008 | 09:29 AM
synergy10's Avatar
Default Re: (GreedyPT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreedyPT &raquo;</TD></TR><TR><TD CLASS="quote">Short=front
Long=rear
You can confirm that by checking the bottom of the spring.</TD></TR></TABLE>
Actually, I just installed my ITR springs and...
Short = rear
Long = front
Old Mar 16, 2008 | 01:30 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (synergy10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synergy10 &raquo;</TD></TR><TR><TD CLASS="quote">
Short = rear
Long = front</TD></TR></TABLE>
wrong!
Long=rear</TD></TR></TABLE>
Old Mar 16, 2008 | 04:36 PM
totsie7944's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">
wrong!
x2
Old Mar 16, 2008 | 07:07 PM
EH3-R's Avatar
Wrong, the rear springs are shorter. The rears are progressive springs (tighter coils on top).
Old Mar 16, 2008 | 07:11 PM
EH3-R's Avatar
Default Re: (EH3-R)
Old Mar 16, 2008 | 07:23 PM
synergy10's Avatar
Default Re: (BlueR)
OP - Sorry if I provided the wrong info.
I'm curious now??? When I first installed the shorter springs on the front, after lowering the car it was pretty low (I mean no gap). So, I went ahead and swapped the springs front to rear and ended up with the longer ones in the front and the shorter ones in the rear?
In this pic, I know the springs are compressed, but it looks to me like the longer ones are in the front and the shorter ones are in the rear.
FWIW - I'm not trying to argue, I just want to make sure I put the springs on the right way also.
Old Mar 16, 2008 | 10:14 PM
Fat Chick Magnet's Avatar
Short = rear
go re-install them the correct way.
Old Mar 17, 2008 | 08:19 AM
synergy10's Avatar
Default Re: (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">
go re-install them the correct way.</TD></TR></TABLE>
As it stands right now, my springs/shocks look just like the ones in the pics above. So, I'll keep it as-is. Like I said, when I put the shorter springs up front, the car had literally no gap.
Old Mar 26, 2008 | 07:59 AM
Ok, so the Longer springs are for the front and the shorter springs are for the rear?
That would make sense I guess after looking at this picture. I just installed the ITR springs on my Koni Yellows going on my 2000 GSR.
I had to use spring compressors on the rear springs to get the top hat on and nuts on. The fronts have about 1.5inch space in them seen in the picture at the top.
The perches on my Koni's are set on the lowest perch.
Old Mar 26, 2008 | 10:21 AM
KOALA YUMMIES's Avatar
Default Re: (92integraVTECgsr)
TO SET THE RECORD STRAIGHT
Make sure to look at those paint marks to ID an ITR spring as well
LONGER=Grey Blue Purple spring is the FRONT
Shorter=Blue Green Purple is the REAR the rear also has the strip of rubber near the tops of the spring
To everyone that misinformed get your facts straight (esp the OGs) I'm sure him and everyone else that was mislead and had to swap springs is very happy with you.
This is how it should be:
Old Mar 26, 2008 | 10:37 AM
CW-ITR's Avatar
Default Re: (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">TO SET THE RECORD STRAIGHT
Amen
Old Mar 26, 2008 | 10:50 AM
Default Re: (CW-ITR)
Thank You very much. So indeed I do have them on backwards. lol. that explains why i could NOT get the rear shocks on.
Old Mar 26, 2008 | 10:55 AM
Yeah, if you search through the archives for "OEM spring" in the ITR forum and whatnot theres some good info, apparently a bunch forgot. I also went and double checked on my 100% oem ITR suspension (off the car) thats never been tampered with and its the same way.
Ultraspeed DC2
Suspension & Brakes
Nov 10, 2006 11:44 AM
Redsun
Suspension & Brakes
May 10, 2006 04:20 PM
FrostyDC4
Jul 26, 2004 03:39 AM
blkgsr03
10
Nov 23, 2003 04:54 PM
JeremyL
Feb 9, 2003 10:30 AM
