Honda S2000 Honda S2000
OE Hardtop help....I going crazy!!!!!
Old Mar 14, 2008 | 07:50 AM
TL1000R's Avatar
Default OE Hardtop help....I going crazy!!!!!
Does anyone have a simple solution to fix rattling hardtop strikers? The damn things will rattle if I even sneeze with the windows up and I'm going fricken nuts. Are you able to adjust the tension on these or am I ultimately going to have to replace them? I saw a great idea on the "How to" threat but it turns out it's for the soft top.
Old Mar 14, 2008 | 07:52 AM
SwampThing's Avatar
i cant help you but i want a hard top.
Old Mar 14, 2008 | 07:54 AM
Techno Tonis's Avatar
Default Re: OE Hardtop help....I going crazy!!!!! (TL1000R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have a simple solution to fix rattling hardtop strikers? The damn things will rattle if I even sneeze with the windows up and I'm going fricken nuts. Are you able to adjust the tension on these or am I ultimately going to have to replace them? I saw a great idea on the "How to" threat but it turns out it's for the soft top. </TD></TR></TABLE>
you need to get new strikers. pretty much the only fix
Old Mar 14, 2008 | 08:01 AM
SwampThing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have a simple solution to fix rattling hardtop strikers? The damn things will rattle if I even sneeze with the windows up and I'm going fricken nuts. Are you able to adjust the tension on these or am I ultimately going to have to replace them? I saw a great idea on the "How to" threat but it turns out it's for the soft top. </TD></TR></TABLE> check out the DIY thread at the top, there is a post that tells you how to get rid of the noise.
Old Mar 14, 2008 | 08:03 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: OE Hardtop help....I going crazy!!!!! (SwampThing)
jb weld and duct tape
/thread
Old Mar 14, 2008 | 08:07 AM
TL1000R's Avatar
Default Re: OE Hardtop help....I going crazy!!!!! (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">jb weld and duct tape
/thread</TD></TR></TABLE>I'd expect nothing less from you, fiti.......LOL
Old Mar 14, 2008 | 08:08 AM
TL1000R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwampThing &raquo;</TD></TR><TR><TD CLASS="quote"> check out the DIY thread at the top, there is a post that tells you how to get rid of the noise. </TD></TR></TABLE> if you read my original thread a little more carefully, you'd see that I already read that and it's for a soft top.
Old Mar 14, 2008 | 08:30 AM
SwampThing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote"> if you read my original thread a little more carefully, you'd see that I already read that and it's for a soft top.</TD></TR></TABLE> d0h, i blame it on not having enough coffee today.
Old Mar 14, 2008 | 09:01 AM
reebs's Avatar
i removed my visors, removed the side pillars going vertically on each side of the windshield, and i found that the car shakes the bolts loose. I tightened them down, and the rattle was gone. so was the wind noise.
Old Mar 14, 2008 | 09:48 AM
jefferyg32's Avatar
Default Re: (reebs)
reebs is right they do rattle loose if Locktight wasnt used. try that. there are also shims you can get maybe you need to shim it tighter or take a shim out if there are shims in it. id try that and see where it takes you
Old Mar 14, 2008 | 10:03 AM
TL1000R's Avatar
Default Re: (jefferyg32)
Thanks for the info. I'll check that out this weekend. I'll pretty much try anything to avoid purchasing new strikers although I will if I have to.
Apocalypse
Honda Motorcycles
84
Nov 12, 2006 01:23 PM
The_Head
Honda Motorcycles
Oct 7, 2006 02:30 PM
JMU R1
Honda Motorcycles
22
Apr 30, 2006 04:44 PM
miamidamian
Apr 14, 2005 09:38 AM
Larkin W.
Jun 10, 2004 06:38 PM
