ECU PROBLEMS????? HELP?
Old Mar 14, 2008 | 06:53 AM
cor4ey's Avatar
Default ECU PROBLEMS????? HELP?
Ok so im running a d16z6 obd1 conversion also was dual port injection now multiport injection. So heres the symptoms, 55mph 2500rpm sometimes just cuts out like not enough fuel or too much fuel? Low rpms from 1000 to bout 4000 its not so smooth then when vtec hits sometimes it loses power sometimes not? Now im running a p0 series ecu not sure which but if you can identify it let me know heres the pic
Now 2 actual questions could the chip in this be bad? Or could it have a chip thats ready for turbo which im not running causing it to run like ****?
Old Mar 14, 2008 | 08:11 AM
zccr-xsi's Avatar
is it showing any codes?have u opened the ecu up yet?
Old Mar 14, 2008 | 09:51 AM
cor4ey's Avatar
Default Re: (zccr-xsi)
Yea I took off the cover thinking it was jumped for a turbo cause I had one but not anymore and there's no jumper and no not showing any codes I'm just curious if it was maybe chipped or if a po8 has the same fuel map as a p28 if not can I get it programmed? Could it be timing? I had it timed by only the distributor they didn't time it to the ecu with the wire thing etc.... any ideas? Should I try a virgin 5 spd p28 see if that makes a diff?
Old Mar 14, 2008 | 11:37 AM
zccr-xsi's Avatar
u could burn u a base map if u want.post a pic of the inside of the computer.
Old Mar 14, 2008 | 11:51 AM
cor4ey's Avatar
I will when I got off work but how do I burn a basemap?
Old Mar 16, 2008 | 05:28 AM
zccr-xsi's Avatar
u need chips and a eprom burner.
Old Mar 16, 2008 | 08:58 AM
jlicrx's Avatar
Default Re: ECU PROBLEMS????? HELP? (cor4ey)
borrow someone's P28 and see if it works right
ek coupe
May 3, 2009 10:26 AM
Powered By Garrett
Engine Management and Tuning
Jun 15, 2008 09:03 AM
tuan...
Jul 17, 2005 07:03 PM
Se-rv-Tak
11
Nov 29, 2003 08:11 PM
743power
Mar 9, 2002 08:52 AM
