Classic Hondas All Pre-1988 Hondas.
1987 CRX SI overheating
Old Mar 13, 2008 | 09:18 PM
RicerJ's Avatar
Default 1987 CRX SI overheating
ok so my 87 crx si is still overheating new water pump new thermo (put in right) new radiator and cap new head gasket (put in right) and the head was even machined and pressure checked and still over heating
Old Mar 13, 2008 | 10:29 PM
Hype-S's Avatar
Default Re: 1987 CRX SI overheating (RicerJ)
its possible that you got a bad thermostat. it might be new but i have seen it before when i used to work at a radiator shop another thing that could be happening is you don't have the system bled right you could have a giant air bubble trapped in side the block. the correct way to do this is to fiill the radiator with antifreeze then allow the car to warm up to operating temperature with cap off eventually the fluid level inside the radiaor will go down and then you top it off and close the cap. im not sure if there are bleeder fitting on that model or not.
Old Mar 13, 2008 | 11:15 PM
tunerkid7's Avatar
Default Re: 1987 CRX SI overheating (Hype-S)
check for air pockets in the system and bleed it
Old Mar 14, 2008 | 09:19 AM
RicerJ's Avatar
Default Re: 1987 CRX SI overheating (tunerkid7)
we have bleed the system every which way possible from jacking the car up on the passenger side to forcing fluid through the bleeder
Old Mar 14, 2008 | 09:31 AM
IT GUY's Avatar
is the thermostat actually opening? I know you said you put it in right, but I've gotten some non-funtional parts store thermostats new in the box.
Old Mar 14, 2008 | 10:04 AM
RicerJ's Avatar
Default Re: 1987 CRX SI overheating (IT GUY)
it opened once i know for fact cuz we had a thermometer in the radiator the best we could and i saw the temp drop on it
reply yes my fan is coming on it got jumped so its always on
also this trial thing is annoying me when is it over
Modified by RicerJ at 12:59 PM 3/14/2008
Old Mar 14, 2008 | 11:21 AM
cbr_ryder's Avatar
Are you getting circulation? Is your fan coming on?
Old Mar 14, 2008 | 11:08 PM
RicerJ's Avatar
Default Re: 1987 CRX SI overheating (cbr_ryder)
ok i got it fixed today there was a blade from the old water pump stuck in the the water jacket where the pump goes you could see it in 2 secs 4 if you had to say where
Old Mar 17, 2008 | 03:50 AM
E-AT_me's Avatar
check for restrictions. sounds like your water pump could have broken a blade in the water jacket.
Old Mar 17, 2008 | 06:55 AM
cbr_ryder's Avatar
Haha, ya that trial **** is really annoying when you go to reply and it says you've reached your limit. I think it took like 10 days to go away.
I can honestly say I've never seen a water pump break fins like that, if anything the bearing goes and/or it starts leaking.
Old Mar 18, 2008 | 02:51 PM
RicerJ's Avatar
yea i've never joined a forum and have a trial thing yea and when all the blades broke off i didnt even lose timing and the adjuster was never even loosened so when we went to loosen it we had to use a 3 foot breaker bar
Old Mar 18, 2008 | 03:24 PM
E-AT_me's Avatar
broken water pumps are extremely common surprisingly in VW's. m wifes' 2.0 99 bug it was a BIG concern for us when we did the timing belt. but, we lucked out and there wasn't any broken fins, but a few cracks. they are made of a composite material, but ours should be metal..
Old Mar 18, 2008 | 10:02 PM
RicerJ's Avatar
Default Re: 1987 CRX SI overheating (E-AT_me)
usually when water pump goes in a Honda it will seize up and bend valves and you will lose timing but i didnt bend valves or lose timing it might have been 6-9 hours of head gasket scrapping but since i have done that i hope it runs for another 221400 miles without anything major
Modified by RicerJ at 8:17 PM 3/19/2008
Old Mar 19, 2008 | 04:04 AM
cbr_ryder's Avatar
Best $20 I ever spent was towing my car to the machine shop and having them clean the head gasket material off my block...That was after 2 hours of scraping and getting nowhere.
Old Mar 19, 2008 | 08:59 AM
RicerJ's Avatar
well if we had any of that gasket softening stuff it would have been a lot easier
Old Mar 19, 2008 | 09:08 AM
E-AT_me's Avatar
no way. that stuff sucks. it just adds more crap to scrape off.
Old Mar 19, 2008 | 07:18 PM
RicerJ's Avatar
well im not saying gasket softener per say just something to soften the gasket up
Old Mar 22, 2008 | 04:00 AM
Sikocivic's Avatar
This is what I use to remove the old stuck on gasket stuff. It will remove all the gasket and NOT cut into the aluminum. Its made out of some type of plastic. I think you can get them at Sears.
http://solutions.3m.com/wps/po...1DPbl
Old Mar 22, 2008 | 02:35 PM
RicerJ's Avatar
Default Re: 1987 CRX SI overheating (Sikocivic)
yea well theres also paint thinner (cant think of what brand my teacher always says)
Old Mar 27, 2008 | 07:29 PM
ice_man_619's Avatar
do you guys think that it is a good idea to convert my 1987 honda civic form a carbureator to fuel injected
Old Mar 27, 2008 | 09:31 PM
RicerJ's Avatar
Default Re: 1987 CRX SI overheating (ice_man_619)
if you wanna really do some major work go for it if you feel like you can do it
Old Mar 30, 2008 | 08:22 PM
CarNutCertifies's Avatar
RicerJ and ice_man_619 have you considered checking things out over at redpepperracing.com? They are a CRX website and could help you guys with any question you have. Even performance mods and step by step stuff. I tried to send a pm and let you guy know there but it wont let me do a pm....
Mod...Not trying to take memebers just help with getting them info they are looking for. Please dont ban me... I look forward to using this site in the future.
Old May 31, 2008 | 03:00 PM
RicerJ's Avatar
Default Re: 1987 CRX SI overheating (CarNutCertifies)
alright guys i need help it started overheating again i got a new thermo but havent installed it yet is it possible for it to go bad so fast? or could it have been bad from the start? but im starting to think that there is another blade stuck in there
Old Jun 2, 2008 | 08:51 PM
RicerJ's Avatar
haha alright i hope its done this time it seems to be running good right now lets just hope it stays that way
Old Jun 7, 2008 | 12:53 AM
RicerJ's Avatar
Default Re: (RicerJ)
damn it just took it from Sac to Chico and back and i think i [freak]ed myself 5 ways from sunday my exhaust heat shield burn a hole in my new radiator and to boot i think i warped my head i think its time i rebuild it it has about 221700
