idle problem!
Old Mar 13, 2008 | 07:39 PM
the_dxB16's Avatar
Default idle problem!
my 93 dx w/b16a engine has an idle that keeps going up and down from 1000 to about 1500. why is it doing that?
Old Mar 13, 2008 | 07:54 PM
crazyguy's Avatar
Default Re: idle problem! (the_dxB16)
try to clean iacv, replace fuel filter..etc.
Old Mar 13, 2008 | 08:23 PM
gigidygigidy's Avatar
Default Re: idle problem! (crazyguy)
maybe firing order
Old Mar 13, 2008 | 09:13 PM
the_dxB16's Avatar
Default Re: idle problem! (gigidygigidy)
It all started when i cleaned the throttle body and replaced the gasket.
Old Mar 13, 2008 | 09:26 PM
Midori Green's Avatar
damn i hate that... officially everybody that i have known in the past like 3 years as soon as they get an aftermarket throttle body they have major idle problems... and on stock motors the effect seems to be even worse
Old Mar 13, 2008 | 10:43 PM
E JAY 1's Avatar
Default Re: idle problem! (Midori Green)
not sure if this would really be the problem but for me my car idle from 1500 to 2000 reasoning being was because i was low on coolant. maybe you should check that
Old Mar 13, 2008 | 10:47 PM
SirRevvs's Avatar
Default Re: idle problem! (E JAY 1)
Sounds like a vaccuum leak, you may have installed the gasket backwards or you didn't cleanall the gasket materialoff the manifold and throttle body before replacing. Easy way to test for vaccuum leak is to put your hand over the throttle body while the engine is running and if it keeps running you got a vaccuum leak. Or you may have gotten the wrong gasket. There's two different styles, a larger one for TB's with a Fast Idle Thermo valve and a smaller one for TB with out a FITV.
Hardedge
Dec 9, 2007 09:18 AM
go2sleep
Jun 27, 2006 01:36 PM
CRX_Control
Nov 7, 2004 07:47 PM
2fknlo
Sep 13, 2004 01:15 PM
PowderB16
Jul 16, 2004 08:34 PM
