Door actuator test, questions (reading off of a integra service manual)
Old Mar 13, 2008 | 07:32 PM
aimbot's Avatar
Default Door actuator test, questions (reading off of a integra service manual)
My power door locks arent working so i want to test my door actuators. The manual im reading says i should apply power to one pin of a connector and ground to another. Now, my question is should i find a wire that is a 12v input, and tap power from that then connection the ground wire to the chassis?
-ps. (im talking about the 6-P connector from the door actuators, thanks!)
Old Mar 15, 2008 | 06:38 PM
aimbot's Avatar
Default Re: Door actuator test, questions (aimbot)
any ideas?
Old Mar 15, 2008 | 08:46 PM
dc2ef9ee2's Avatar
Yes, use a 9volt battery or cordless drill battery (9.6volt or 12 volt). 1 side 12volt constant and other side ground. it should lock or unlock, then reverse the wires it should do the opposite. Make sure unplug the six pin harness.
Telecatster
Dec 2, 2013 02:17 PM
Dropped90Integra
Feb 2, 2005 09:00 AM
