thinking bout making a tranny cooler for my 5 speed tranny ?
Old Mar 13, 2008 | 03:53 PM
h22 civic's Avatar
Default thinking bout making a tranny cooler for my 5 speed tranny ?
what ya think worth it or not ..i know i feel a tramendeous difference in my tranny when it is not hot
Old Mar 14, 2008 | 12:14 PM
h22 civic's Avatar
Default Re: thinking bout making a tranny cooler for my 5 speed tranny ? (h22 civic)
Old Mar 14, 2008 | 01:04 PM
PolishSasquatch's Avatar
if you have the time patience and money then do it up? will definitly help it out in the long run
Old Mar 14, 2008 | 01:17 PM
h22 civic's Avatar
Default Re: thinking bout making a tranny cooler for my 5 speed tranny ? (PolishSasquatch)
yea,,maybe im thinking it to fast but i figure i got the case apart already weld 2 fittings ( a feed on botttom and a return on top) ill make the return a bit bigger and bushing it down to the size i need for the return so i could use it to fill the tranny when changeing fluid..then come out the feed into a tranny fluid pump with check valve ,,some line into a tranny cooler and fittings ,,,and some power and its done could even put a magnetic filter in also
Old Mar 14, 2008 | 04:52 PM
Kraz13's Avatar
umm...as far as i know our manual trannies just sorta splash the fluid around, theyse no pump to actually pump it anywhere. (i don't think any manual tranny has a pump )
By putting one fitting at the top and one at the top it won't go anywhere...you would have to install a pump as well, and do way too much work for nothing.
Old Mar 14, 2008 | 05:56 PM
h22 civic's Avatar
Default Re: (Kraz13)
priceless!
Old Mar 14, 2008 | 06:09 PM
standbackimapro's Avatar
Manual Transmissions Fluid just jumps around the gears.
Automatic transmissions ( is what has transmission coolers) has valves and solenoids which let fluid get to different parts..
First off its gonna be hard to attach nipplies to the transmission since its like cast.. and second. the fluid wont be pumped anywhere...
You would have to rig up a system to pump the fluid out of the transmission, through a cooler, and back into the trans which means at one point the transmission will probably be about a quart low on fluid because it will be going through the pump
Old Mar 14, 2008 | 06:25 PM
h22 civic's Avatar
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">priceless!</TD></TR></TABLE>x2
slo_ej8
Apr 8, 2008 05:04 PM
twitchzx6rr
Nov 20, 2007 04:06 PM
TurboEM1
23
Apr 28, 2006 04:09 AM
Team 4R
Aug 18, 2004 11:11 PM
