Wheel Bearing Problem
The Driver side is makin aloota noise and it seems to wobble a bit too.. like somethings loose.. we changed the axles and the halfshaft but it still does it.. do you guys think its the wheel bearing or is it something else?
From: Fremont, california, united states of america
Lift the car until the suspected axle is off the ground. Grab hold of the wheel (still attached to the car),and rock it up and down (vertical axis) and side to side (horizontal axis). If there is play and a usually an audible clunk in both axis,then your wheel bearing is suspected to be bad. If there is play side to side on the horizontal axis, then your tie rod assembly (inner or outer,or sometimes both). is suspected to be bad.
GL with the fix, pray its a tierod, because wheel bearings are difficult x 1,000,000
ketchup
17
Jun 27, 2008 09:02 PM
