over heating problem in my b18b
Old Mar 13, 2008 | 03:28 PM
grnhatch94's Avatar
Default over heating problem in my b18b
its really weird cuz if it idles it slowly start to overheat the i rev up and it goes down . the fan is not activating so i think its the fan switch but can someone give me advice.
Old Mar 13, 2008 | 03:33 PM
JDM_SOHC's Avatar
Default Re: over heating problem in my b18b (grnhatch94)
well do the lil speakerwire test of the fan to see if its even workin, "positive/negative wires to the battery to see if it gets power" an if ur switch is bad just jumper the switch so uf fan comes on with ignition an u should be all good...
Old Mar 13, 2008 | 03:46 PM
grnhatch94's Avatar
Default Re: over heating problem in my b18b (JDM_SOHC)
thanx for the advice
Old Mar 13, 2008 | 03:50 PM
97civic94gsxr's Avatar
You could also run the wires through a toggle switch in the cabin so your fan isnt always running
Old Mar 13, 2008 | 04:11 PM
JDM_SOHC's Avatar
Default Re: over heating problem in my b18b (97civic94gsxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic94gsxr &raquo;</TD></TR><TR><TD CLASS="quote">You could also run the wires through a toggle switch in the cabin so your fan isnt always running</TD></TR></TABLE>
whats bad about having the fan always running..?? since my cars boosted im creatin massive more amounts of heat an havin my fan on all the time im pretty sure does me more good than bad... but i've had my fan setup like it is for quite a while now an it seems fine... i was just tryna give'm an alternative to spendin any money...
Old Mar 13, 2008 | 04:17 PM
if you're running boost and need extra cooling thats fine i was just letting him know of other alternatives than wiring the fan to always run.
Old Mar 13, 2008 | 04:19 PM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civic94gsxr &raquo;</TD></TR><TR><TD CLASS="quote">if you're running boost and need extra cooling thats fine i was just letting him know of other alternatives than wiring the fan to always run.</TD></TR></TABLE>
oh ight cool, i thought u were tryna say that its kinda stupid to do it that way instead of purchasing the switch... either way, they're both good ideas, an both guarenteed to work lol..
Old Mar 13, 2008 | 05:46 PM
grnhatch94's Avatar
thanx for all the info but if it was overheating if u rev up the temp gauge wouldnt just go down like that. does anyone else have had this type of prob
Old Mar 14, 2008 | 02:54 AM
grnhatch94's Avatar
up
Old Mar 14, 2008 | 06:16 AM
MuddinPede's Avatar
My D16Z6 in my '93 Si does that from time to time. Just a slight blip on the gas and it starts goin down usually. When my radiator blew I had to use a few autozone parts to get it runnin, one of which was a thermostat(Honda is 45 min away). I figured it may be that, and i'll probably try to get one tomorrow or next week.
kirkland08
Mar 5, 2011 01:15 PM
lrcrx90
10
Apr 10, 2007 01:44 PM
trrbl1bmx
16
Aug 2, 2006 11:51 AM
97grnrs
Mar 17, 2006 01:54 PM
riceball777
Apr 29, 2003 09:38 AM
