DC JDM 4-1 on '97 Teg LS. Will it fit?
I want to buy this header, I already have 2.5in piping, and a 2.5 test pipe, all waiting to be installed. I am curious if this header will bolt right up to my LS?
Thanks.
[Modified by ilsoc, 11:32 AM 7/8/2002]
Thanks.
the header will bolt to the head, but your going to have to modify the cat and stuff, cuz its a different length compared to a ls header so you would have to take it a muffler shop to fix it.
It depends on the test pipe. IF the test pipe was made for a jdm header, then it will fit. The jdm header has the same length as the stock LS header, it's just the collector flange that's different.
no the length for the JDM one is the same as the LS...but the flange mite be angled slightly differently...no matter if ur getting a high flow cat or testpipe on there thoguh
I wish people wouldn't fukn post if they're WRONG.
LOwrestling is right, the collector flange is angled different so it depends on your test pipe flange.
Thanks for the reply's. Now I know the header will fit, as for the test pipe, I already have one laying around in the garage, 2.5in also. Thanks...
boywonda
Oct 7, 2003 05:44 AM
