Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
ITR/CTR hp/tq gain in a stock b16a sir2
Old Mar 13, 2008 | 12:35 PM
Elwuudz's Avatar
Default ITR/CTR hp/tq gain in a stock b16a sir2
What would be a reasonable estimate of hp/tq gain in a stock b16a sir2 with
ITR cams
would mixing ctr and itr benifit me at all and if so how should i mix them?
I heard with tuning they might be good
Old Mar 13, 2008 | 02:21 PM
Lo-Buck EF's Avatar
Default Re: ITR/CTR hp/tq gain in a stock b16a sir2 (Elwuudz)
since b16 cams are weak, its well worth it to swap to itr/ctr. my p30 b16 made 160wheel with itr cams. although i think that's a high number, there still as a hp gain from itr cams. prolly 10hp
Old Mar 13, 2008 | 02:34 PM
I makes it RAIN's Avatar
only diff. between ITR & CTR is the intake cam. Both have the same exhaust cam.
Old Mar 13, 2008 | 03:21 PM
Elwuudz's Avatar
Default Re: ITR/CTR hp/tq gain in a stock b16a sir2 (Lo-Buck EF)
werd
I'm hoping to hit 160whp without the cams first then swapem in; the butt dyno says its almost time to hit the real dyno
Old Mar 13, 2008 | 03:22 PM
Elwuudz's Avatar
Default Re: ITR/CTR hp/tq gain in a stock b16a sir2 (I makes it RAIN)
good 2 know
I will run some ITR cams then
Old Mar 13, 2008 | 03:52 PM
CTR intake cam is hotter than ITR intake cam. FYI
Old Mar 13, 2008 | 04:06 PM
Lo-Buck EF's Avatar
CTR>ITR>98 AND DOWN ITR
Old Mar 13, 2008 | 06:02 PM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz &raquo;</TD></TR><TR><TD CLASS="quote">I'm hoping to hit 160whp without the cams first then swapem in; the butt dyno says its almost time to hit the real dyno </TD></TR></TABLE>
What has been done to the engine? What are your plans for car?
Old Mar 14, 2008 | 04:53 AM
RoadRacer46's Avatar
FYI, H-Motors online has ctr intake cams for $219.00
Old Mar 21, 2008 | 11:56 AM
Elwuudz's Avatar
Default Re: ITR/CTR hp/tq gain in a stock b16a sir2 (o-man)
Quote, originally posted by Elwuudz »
2mo old Engine swap
B16a Sir2 pristine condition
Hasport Mounts
7.5lb flywheel+fresh clutch :: exeddy/exeddy
Alternating between AEM chopped cold air with fujita filter and whale *****
Crusty megan header for now
SP2 catback
New rich porter distributor with external module
Wires/ Plugs NGK Platinum Power
CTR pulley/ no AC or PS
Titanium drive axels
Micro polished wheel bearings
11lb PIAA wheels with new rubber gforce sports 205/50/15
I was hoping some ITR cams and a Manifold a new TB and a set of fresh Injectors would liven up this setup a bit; I plan on getting it mapped with s300 later in the year
I plan on foolin around in HPDE and NASA with in the year
rico suave
May 27, 2012 09:32 PM
BigAnold
Jul 1, 2005 06:33 PM
JDMlyfestyle
Nov 1, 2003 06:26 PM
PrOjEkT ED9
Sep 2, 2002 02:40 PM
Nighthawk GS-R
Mar 7, 2002 09:22 PM
