New guy and car won't start
Old Mar 13, 2008 | 12:14 PM
92accordjohn's Avatar
Default New guy and car won't start
I was driving my 92 accord it died put gas in nothing checked battery nothing alternator nothing and the list goes on and someone please shine a little bit of light my way on this.
Old Mar 13, 2008 | 02:59 PM
hondadude's Avatar
Default Re: New guy and car won't start (92accordjohn)
Engine cranks over but will not run?
When the car died did the dash warning lights come on?
Do you have spark at the spark plugs when cranking?
Fuel pressure at the fuel rail test port?
Can you hear the fuel pump run a few seconds when the key is turned on?
Come on throw us a bone here, we need a little info to chew on.
Old Mar 13, 2008 | 04:28 PM
erk89's Avatar
Default Re: New guy and car won't start (hondadude)
is there a banana in the tailpipe? lmao yea like hondalude said, we need more scraps
Old Mar 20, 2008 | 09:15 AM
i have feul going threw the feul replaced distruber, plugs and wires. and still no spark.
Old Mar 20, 2008 | 01:31 PM
f22kid's Avatar
thats kind of weird i have the same problem i replaced my timing belt and balance shaft belt and all that stuff wires are new im getting spark at the plugs and gas and it still wont fire it sputters every other revolution after i did the timing it ran for a couple f days then i went out to start it this morning and it wont run......
Old Mar 20, 2008 | 05:43 PM
hondadude's Avatar
Default Re: New guy and car won't start (f22kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22kid &raquo;</TD></TR><TR><TD CLASS="quote">thats kind of weird i have the same problem i replaced my timing belt and balance shaft belt and all that stuff wires are new im getting spark at the plugs and gas and it still wont fire it sputters every other revolution after i did the timing it ran for a couple f days then i went out to start it this morning and it wont run......</TD></TR></TABLE>
It doesn't cost you a penny to start your own thread instead of JACKING someone elses. Thread jacking can cause a lot of confusion for the OP, and others trying to be helpful
Old Mar 20, 2008 | 05:45 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92accordjohn &raquo;</TD></TR><TR><TD CLASS="quote">I was driving my 92 accord it died put gas in nothing checked battery nothing alternator nothing and the list goes on and someone please shine a little bit of light my way on this.</TD></TR></TABLE>
can you use a test light to be sure you have 12V at the Black/yellow wire at the Dist when the key is on, that will show the ignition switch is good.
You replaced the entire dist? or the cap?
Bobdontwork
May 25, 2014 03:53 AM
quad
20
Mar 14, 2007 05:16 AM
0418accord
Feb 22, 2007 11:55 AM
blkwidow420
May 24, 2004 02:35 AM
riceboyEFsi
Mar 3, 2003 09:00 AM
