wiring harness problem
Well I was gonna extend the connectors by the passenger side strut tower so I could tuck them some, well on the first connector I cut and extended all the wires and then realized there are 2 black, 2 green/black and 2 yellow/blue. So know Im stuck trying to figure out which ones go where winces theres 2 sets of each
its obd2, theres 5 connectors on the passenger side, 3 are gray, 2 of the gray are male ends, its the gray male 14 pin not the gray male 10 pin
I cant find my camera, right next to the cruise control thing theres five connectors, 2 are blue, 3 are gray, 2 of the gray are male, one is 10 pin the other is 14, I need the 14 pin one
i think those are for you fuse box/abs connecetors, next time for future refrence irocmend some tape to label, i always label before i cut, better safe then sorry, ill take pics of mine if thatle help?
ok i need you to follow the wires to the TCM and tell me the pin locations and which connector.
looking into the back of the connector (where the wires go in), the top left is 1. The pin to the direct right of that is 2. bottom right is the last pin.
connector A has 26pins, connector B has 22 pins.
once we figure out what each wire is on one side, the rest is easy.
going into atts:
YELLOW/BLUE---yellow/green---yellow/red
GREEN/BLACK---blue---BLACK---black/yellow
GREEN/BLACK---brown---BLACK---red/white
blue/white---YELLOW/BLUE---green/yellow
connection at shock tower:
yellow/green---black/white---red/white
brown---BLACK---green/yellow---BLACK
YELLOW/Blue---blue---GREEN/BLACK---YELLOW/BLUE
yellow/red---blue/white---GREEN/BLACK
I did these both the the little nub the connector snabs over on the top.
ones in caps are my problems.
