Beaks Subframe Bar...
Old Mar 13, 2008 | 08:04 AM
ITR010342's Avatar
Default Beaks Subframe Bar...
I was wondering if it will fit on the Type R? And I know everyone will say "buy ASR!", but I am just asking. Also, I have searched it to no results, so any help is appreciated!
Old Mar 13, 2008 | 08:22 AM
crx(gator)'s Avatar
Default Re: Beaks Subframe Bar... (ITR010342)
i thought these subframes were used on non-itrs so they can run an itr rear swaybar?
Old Mar 13, 2008 | 08:33 AM
totsie7944's Avatar
I assume you are talking about the Beaks lower tie bar? If so, they make one for the ITR, but there is no performance gain over stock...
Old Mar 13, 2008 | 08:52 AM
ITR010342's Avatar
That's what I figured, but just wanted to make sure! Thanks for the help!
Old Mar 13, 2008 | 02:28 PM
Junior Wock's Avatar
Default Re: (ITR010342)
It looks good
Old Mar 13, 2008 | 03:48 PM
JjuuN R's Avatar
Default Re: Beaks Subframe Bar... (totsie7944)
EEENNNTTT, wrong, you can use the Beaks tie bar in conjunction with the factory tie bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR010342 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if it will fit on the Type R? And I know everyone will say "buy ASR!", but I am just asking. Also, I have searched it to no results, so any help is appreciated! </TD></TR></TABLE>
The ASR is the one that won't fit on an ITR subframe.
Old Mar 13, 2008 | 04:38 PM
championR's Avatar
so it is generally said that itr's do not need subframe reinforcing? how about if u step up to an alex 25mm rear sway or a aspec 32mm?
Modified by championR at 6:07 PM 3/13/2008
Old Mar 13, 2008 | 06:27 PM
SuckMyDOHC's Avatar
Default Re: (championR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by championR &raquo;</TD></TR><TR><TD CLASS="quote">so it is generally said that itr's do not need subframe reinforcing? how about if u step up to an alex 25mm rear sway or a aspec 32mm?
Modified by championR at 6:07 PM 3/13/2008</TD></TR></TABLE>
Nope, the ITR subframe is strong enough for those. A stiffer spring rate will also help as well
Old Mar 13, 2008 | 06:32 PM
totsie7944's Avatar
Default Re: Beaks Subframe Bar... (JjuuN R)
how is that wrong? He was talking about the Beaks tie-bar, not the rear sway bar.
The Beaks tie bar can be used in conjunction with ANY rear sway bar. The ASR subframe support cannot be used on a ITR, and there is no need as the ITR was reinforced from the factory. Even as big as the ASR 32mm sway you are fine.
The subframe support can be modified to fit on the ITR if you are looking for *bling*, but is a complete waste of money.
Old Mar 14, 2008 | 05:43 AM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">how is that wrong? He was talking about the Beaks tie-bar, not the rear sway bar.
The subframe support can be modified to fit on the ITR if you are looking for *bling*, but is a complete waste of money.</TD></TR></TABLE>
I know what he was talking about, and I wasn't talking about sway bars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">EEENNNTTT, wrong, you can use the Beaks tie bar in conjunction with the factory tie bar.</TD></TR></TABLE>
Did you see me say anything about a sway bar? Or are you seeing things?
Old Mar 14, 2008 | 06:54 AM
totsie7944's Avatar
Your reply was to my comment and you said it was wrong? Hence why I was wondering what you were talking about because what I said was correct that Beaks makes one for our car but offers no improvement over stock?
Old Mar 16, 2008 | 04:15 AM
twelvetm's Avatar
where can i get the aspec 32mm?
Doostur
Apr 16, 2008 09:41 PM
JDM_FRONTIN
Suspension & Brakes
Oct 22, 2007 10:27 AM
silver_nteg
Jun 18, 2004 10:47 PM
BrownGSR
Nov 11, 2003 12:41 PM
DB8
Dec 18, 2002 11:07 AM
