Who sells O2 Simulators
Wasnt a law past last year that made the sell of 02 fixes illegal?
Right after I saw that article I noticed all the "sim fixes" had gone away.
You can always make your own homemade version. It isnt hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow v2 »</TD></TR><TR><TD CLASS="quote">or you just get 18mm spark plug non-foulers...drill a 1/2" hole in the end of it..and thread it in, bam...no more CEL</TD></TR></TABLE>
Pep Boys
Pep Boys
Do what he said. It's super easy and it works! Search HT for the How to thread
The problem with those and other solutions (like wrap it in tin foil, yadda yadda.....) is the fact that they works for some people and others have nothing but problems with them. Also, they certainly won't pass a visual inspection.
My plug and play o2 sensor foolers don't look like anything that isn't oem honda because I use oem honda connectors. They can be used with the stock secondary o2 sensor in the exhaust stream (of a cat or test pipe) or you can pull the o2 sensor into the cabin and zip tie it behind your console - either way you will NEVER get a code, even if you are running a test pipe.
I only make them to order and generally only for friends. I'm actually in the middle of making a couple for todd00 and bbasso just to help them out. If you actually NEED one, then shoot me a pm. I'm not a shop and am not trying to start up a business.
I tried looking on ebay and no looking. The o2 extender from blox will do me no good. The O2 will not fit. So far Im looking toward blackr and the weaponr website.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">heh, i make them to order so availability is up to you guys.
I guess I'l send you another PM then.
</TD></TR></TABLE>I guess I'l send you another PM then.
Black R I'm hoping to get one of your O2 Sims to get rid of the CEL on the 96 my son just bought, but I'm new to this forum and I'm unable to PM you. Thanks
