Rear 91 crx si brakes the same as 94+ integra?
quick question
Are the rear 91 crx si brakes the same as 94+ integra. Rear trailing arms the same also?
I know the front isnt but what about the rear
What do you mean using the proper upper control arm and lower. sorry but im fairly new to swaping brakes.
Correct me if im wrong, but can't i install Rear 94+ rotors and calipers on the stock crx si.
basicly if i bought two rear 94+ rotors and calipers would they bolt on my back suspension from my 1991 crx si
http://fourthgenhatch.net/reardiscswap.html
https://honda-tech.com/zerothread?id=1513752
https://honda-tech.com/zerothread?id=1409056
https://honda-tech.com/zerothread/1811368
While these links maybe in different forums they still apply. And yes you can swap the hubs/spindle on the rear from one trailing arm to another. Or you can swap the entire trailing arm.
All the above info can be found in the FAQ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lak8 »</TD></TR><TR><TD CLASS="quote">What do you mean using the proper upper control arm and lower. sorry but im fairly new to swaping brakes.
Sure you could, but it is not an upgrade. They are the same size brake components. Unless you have the 91 CRX Si bare rear trailing amrs and are looking to put the Integra rear disc brakes on them because you can easily get them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lak8 »</TD></TR><TR><TD CLASS="quote">Thanks for the help guys, I was always wondering since people always say you can use 90-93 integra brakes but never the 94+ integra</TD></TR></TABLE>
That is for the front because the knuckles are different. You can use 90-93 Integra knuckles and swap the 94-01 Integra brake components onto the 90-93 Integra knuckles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
I like the sounds of that!!
more parts availability
</TD></TR></TABLE>I like the sounds of that!!
Rear trailing arms are the same for 88-00 Civics (crxs) 90-01 Tegs.. dels sols too.
You would need to use your stock arms (besides rear trailing) and you would need to use Crx e-brake cables (or wrap the hell out of the other ones)
-Shane
-Shane
B2FiNiTY
17
Mar 25, 2004 03:17 PM
