Went to change my wheel bearing/hub assembly...
Old Mar 13, 2008 | 04:04 AM
The_Honda_Guy's Avatar
Default Went to change my wheel bearing/hub assembly...
My right wheel bearing was finally starting to give out after making the lovely growling sound for a couple months and I noticed that it had started to get loose. I figured I'd replace it since I won't be doing my 5 lug swap for a while yet. I was told that my car had a 94 front with a 97 rear, so I figured the suspension was also from a 97. So I order a wheel bearing/hub assembly for a 97 and when I go to put it on it doesn't fit. The 97 assembly is about 2 inches longer than the 94. I could barely even get the nut to fit onto the spindle without the thrust washer. Wierd thing is that I thought 94-97 was all the same suspension pieces, but apparently I was wrong. Today I'm going to go get a new assembly for a 94 and try it again tonight. I also realized why the ABS light always came on too - the sensor wasn't plugged in on the rear axle. Not that it was a big deal because I hate ABS, but it's nice to figure some things out. At least now I know that everything but the rear section of the body is 97 on the car and everything else is 94.
Old Mar 13, 2008 | 03:15 PM
I figured out what the problem was today. I had the right box, but the wrong wheel bearing/hub assembly in it. I took it to a different store to compare it with the one they had in stock and found out that the one I bought wasn't the right piece. I got the correct one and will be putting it on tonight.
suspendedHatch
16
Aug 11, 2009 05:17 PM
7808
Sep 10, 2007 04:42 PM
Streetneon2185
Jun 5, 2007 09:39 PM
gnar kill
Oct 24, 2006 04:04 PM
DeDonDeRosa
Sep 19, 2002 06:52 AM
