FAILED STATE REF. NEED SOME HELP!!!
Old Mar 12, 2008 | 10:29 PM
HARI.'s Avatar
Default FAILED STATE REF. NEED SOME HELP!!!
Modified by HARI. at 2:23 PM 4/12/2008
Old Mar 13, 2008 | 09:44 AM
Speed_1's Avatar
whens the last time you disconnected the battery? It could be since its OBDII it take a little wait to register. I am going to state Ref here in a week. Good luck and let us know if you get it figured out in the mean time.
Old Mar 13, 2008 | 10:45 AM
HARI.'s Avatar
Default Re: (Speed_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed_1 &raquo;</TD></TR><TR><TD CLASS="quote">whens the last time you disconnected the battery? It could be since its OBDII it take a little wait to register. I am going to state Ref here in a week. Good luck and let us know if you get it figured out in the mean time.</TD></TR></TABLE>
i disconnected the battery about 2 weeks before the state ref. been driving it back and forth to work before the state ref appt (30 mi one way).
Old Mar 13, 2008 | 02:17 PM
Speed_1's Avatar
whos doing the Test for you? in what city?
Old Mar 13, 2008 | 06:04 PM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed_1 &raquo;</TD></TR><TR><TD CLASS="quote">whos doing the Test for you? in what city?</TD></TR></TABLE>
rio hondo college
Old Mar 14, 2008 | 05:20 AM
outlawracer1's Avatar
Default Re: (HARI.)
according to what he wrote. You need the charcole canister for the ITR. You might also want to replace the ECU. That's what I had to do. I have a 1993 SI with a 1995 GS-R and I had to go through all those steps. And the same person ref'ed my car. Beleive its worth the hassle to go through this.
Old Mar 14, 2008 | 06:04 AM
HARI.'s Avatar
Default Re: (outlawracer1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outlawracer1 &raquo;</TD></TR><TR><TD CLASS="quote">according to what he wrote. You need the charcole canister for the ITR. You might also want to replace the ECU. That's what I had to do. I have a 1993 SI with a 1995 GS-R and I had to go through all those steps. And the same person ref'ed my car. Beleive its worth the hassle to go through this.</TD></TR></TABLE>
yeah i forgot about the charcoal canister. that was my fault . i've already replaced it. why did you have to replace your ecu? how did you fix the evap system so the obd2 scanner can scan it?
Modified by HARI. at 7:15 AM 3/14/2008
Old Mar 14, 2008 | 07:28 AM
Default Re: (HARI.)
I didn't have to do the evap test. That's a new thing that they started doing this year. I ref'ed my car exactly two years ago. I just had to smog my car in January. And that's when I found out about the evap test. Did you check to see if your purge valve is good. Maybe that's why your ECU isn't reading it. And the reason I replaced the ECU in my car was because when they scanned it it showed up as faulty. So Gustavo said it was probably moded at one point. So I changed it. And it passed after that.
Old Mar 14, 2008 | 09:31 AM
thesmogman's Avatar
Yes the new EVAP / LPFET test started Dec,1 07. All it does is pump a little air into the gas tank to see if there are any leaks. When we do this test we pinch off the hose from the gastank to the charcoal cannister. We do not test the charcoal cannister. This test is for vehicles 1995 and older. 1996 and newer have onboard tests that are run called monitors that check for leaks in the EVAP system. Out of 3-400 cars that my stations have tested only 3-4 cars have failed these tests.
For the OP, Your ECU is not supporting the EVAP monitor. Either it has been modded or something else. There are three states that the monitor can be in.
It is either "not supported", "incomplete" or "complete" By what the ref wrote your ECU has it listed as not supported which is your problem.
Old Mar 14, 2008 | 05:18 PM
HARI.'s Avatar
Default Re: (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">
It is either "not supported", "incomplete" or "complete" By what the ref wrote your ECU has it listed as not supported which is your problem.</TD></TR></TABLE>
damn, so i gotta find another ecu.
Old Mar 15, 2008 | 01:02 AM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outlawracer1 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't have to do the evap test. That's a new thing that they started doing this year. I ref'ed my car exactly two years ago. I just had to smog my car in January. And that's when I found out about the evap test. Did you check to see if your purge valve is good. Maybe that's why your ECU isn't reading it. And the reason I replaced the ECU in my car was because when they scanned it it showed up as faulty. So Gustavo said it was probably moded at one point. So I changed it. And it passed after that.</TD></TR></TABLE>
so when you took your car in back at the ref for the 2nd time, did he throw it back on the sniffer, or did gustavo just inspected what needed to be corrected?
Old Mar 15, 2008 | 07:30 AM
thesmogman's Avatar
Default Re: (HARI.)
Yes, he has to do the whole test again.
It is the way the smog machine/system works.
Jazzy Jeff 978
May 11, 2008 12:53 PM
Blazen_angles
Dec 26, 2007 08:49 PM
slowd16y8
Jun 18, 2007 10:25 AM
^Sammy]!.
Sep 8, 2006 09:26 AM
95ejjj
Jan 8, 2006 05:44 PM
