ls turbo
i have a 94 ls
i recently bought
a GT28R garrett turbo
hondata s300 ecu
greddy piping kit
greddy bov
mishimoto intercooler
oil lines/fittings
other than a manifold, wastegate, and a downpipe what else would i need?
i recently bought
hondata s300 ecu
greddy piping kit
greddy bov
oil lines/fittings
high pressure oil pump
higher cc injectors
boost,air/fuel ratio, and oil pressure guages
boost controller
dump tube
and a damn good tune
I think thats it, but I could have missed something
higher cc injectors
boost controller
dump tube
here is a link of a what is needed and how to. and also, i wish people would stop posting when they are not correct in what they are posting and giving people incorrect information. the stock oil pump will be sufficient. stock fuel system is good to about 250+ hp. and yes, you did miss something, search next time before you offer information. incorrect information anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote">here is a link of a what is needed and how to. and also, i wish people would stop posting when they are not correct in what they are posting and giving people incorrect information. the stock oil pump will be sufficient. stock fuel system is good to about 250+ hp. and yes, you did miss something, search next time before you offer information. incorrect information anyway. </TD></TR></TABLE>
To support added air induction, more fuel is need... hence bigger injectors. Buy size according to application
that was taken directley from the link that you provided.
he may not "need" a high pressue oil pump but its never a bad idea. same thing with the injectors they may not be needed but they are definantly not hurting anything.
stock will work, do some home work. there are several threads on thisl. i understand that its not a bad idea to do, but why spend the money when you don't have to?
