Broken stud
Is there any way I can get my wheel off w/out ruining it? I don't care if the rim gets a little damaged as long as I can still drive on it. They're 17x7 ADR Visions
I had this problem on my DD Civic. I just took a chisel and a hammer and kept hitting it til I was through the lug all the way. I did this on steelies though so I really wasn't worried. I've heard the weld something on the end of the lug trick works pretty good sometimes I would try that.
waht i've done in the past is, remove all the other lug nuts, then kind of pry up the wheel a little, which applies outwards pressure on the stud, then hit it with the airgun.
it might help keep the stud still while spinning the nut off.
