Suspension & Brakes Theory, alignment, spring rates....
Koni Yellows. Mounting Perch? which is the right way?
Old Mar 12, 2008 | 06:49 PM
92integraVTECgsr's Avatar
Default Koni Yellows. Mounting Perch? which is the right way?
I just bought some koni yellows and cannot tell from their instructions. Which is the right way the spring perch should be? #1 or 2
Old Mar 13, 2008 | 08:48 AM
slammed_93_hatch's Avatar
Default Re: Koni Yellows. Mounting Perch? which is the right way? (92integraVTECgsr)
Old Mar 13, 2008 | 03:00 PM
Default Re: Koni Yellows. Mounting Perch? which is the right way? (slammed_93_hatch)
bump
Old Mar 13, 2008 | 03:24 PM
Infinity_Racer's Avatar
Old Mar 13, 2008 | 04:53 PM
Targa250R's Avatar
be professional
Since those are the fronts, #1 is correct.
If they were the rears (which use a larger, differently-shaped perch), #2 would be correct.
Old Mar 13, 2008 | 08:23 PM
Default Re: Koni Yellows. Mounting Perch? which is the right way? (Targa250R)
thanks everyone.
Old Mar 14, 2008 | 11:47 PM
bigwally9876's Avatar
awesome, ima going to be installing my set as soon as my car starts acting right and i had the same question
92integraVTECgsr
Mar 12, 2008 07:41 PM
JFG Kevin
May 7, 2004 02:55 AM
jaM3s Bond
Mar 6, 2003 09:57 AM
Civicboy
Sep 28, 2002 02:10 PM
taytay333
Mar 26, 2002 03:54 PM
