post up your pulse settings
Old Mar 12, 2008 | 05:03 PM
manifoldmiketyson's Avatar
Default post up your pulse settings
i've been using pulse a lot more lately and its making my life a lot easyer. just wondering if anyone else is too?
on manifolds (sch10)
peak: 110
background: 15
% on : 40
pps: 0.7
gas: 20 cfh
rod: 1/16 on crevis, .045 on flat.
Modified by manifoldmiketyson at 4:14 AM 3/14/2008
Old Mar 12, 2008 | 05:29 PM
ROTARY's Avatar
what machine are you using? on my dynasty 200dx i cant use the pulse function past 90 peak amps.
Old Mar 12, 2008 | 06:04 PM
Default Re: (ROTARY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROTARY &raquo;</TD></TR><TR><TD CLASS="quote">what machine are you using? on my dynasty 200dx i cant use the pulse function past 90 peak amps.</TD></TR></TABLE>
lincoln invertec 205
thats nuts, i can pulse up to 200 amps if i want (150 if i'm using 110v).
Old Mar 12, 2008 | 09:02 PM
RCautoworks's Avatar
Default Re: post up your pulse settings (manifoldmiketyson)
I have a miller, I don't think its setup the same. I only have the option for pps per minute I believe... I don't really mess with it to much though.
Old Mar 13, 2008 | 06:38 AM
HT Chaplain's Avatar
Loved
what year dynasty is that??
Old Mar 13, 2008 | 02:03 PM
Bailhatch's Avatar
Default Re: (HT Chaplain)
I mostly use pulse on 19 and 20g mild steel butt welds for body work...probably 28-33peak, 10 background and 2.3pps I think. 17 cfh, 035" Er70-s2
Old Mar 13, 2008 | 07:14 PM
Default Re: post up your pulse settings (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">I have a miller, I don't think its setup the same. I only have the option for pps per minute I believe... I don't really mess with it to much though. </TD></TR></TABLE>
i have the same, i just couldn't remember pps. frequency sounded alright, but fixed now.
Old Mar 14, 2008 | 12:41 AM
ROTARY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain &raquo;</TD></TR><TR><TD CLASS="quote">
what year dynasty is that??</TD></TR></TABLE>
it was built July 07, not sure what i was thinking but i mistaked(spelling?) peak t and peak A .... i got 200 peak amps
Modified by ROTARY at 2:27 AM 3/14/2008
Modified by ROTARY at 2:28 AM 3/14/2008
Old Mar 14, 2008 | 06:58 AM
PSI2HI's Avatar
Former Vendor
No pulser for this guy
Old Mar 14, 2008 | 12:45 PM
mrbsponge's Avatar
I am way too newb for the pulse, haha
although i have been tryin it on some aluminum beads, and it does seem to work well. tryn to jot some settings down for future posting
Old Mar 15, 2008 | 04:38 AM
Tigre Tuning's Avatar
mike on the miller i believe its not amperage that it uses but percentage of the overall amperage so if you set up @ 100 amp and we go to 90 that means the peak will only 90%=90amps and 15 would be 15%=15amps
Old Mar 16, 2008 | 08:45 PM
1 2 NV's Avatar
Default Re: (Tigre Tuning)
ive been welding alot of aluminum lately with my syncrowave 200. i weld it normally but since i havent seemed to perfect my abilities i use the pulser to "clean" them up.
Old Mar 17, 2008 | 05:00 AM
Default Re: (1 2 NV)
i've been pulsing by foot and the machine and either way it looks better then not pulsing at all. you can run a lot more amperage as well as get more penitration without burning the material.
aluminum pulse seems to work the best. stainless is a little tricky to get everything setup right.
Old Mar 17, 2008 | 06:01 PM
Turbo-charged's Avatar
Default Re: (manifoldmiketyson)
ive had a pulser sitting in my tool box for like 2 years that ive never installed. i'd like to try it out one day haha
pulsers seem to be like AEM. people either love it or hate it
Old Mar 19, 2008 | 10:14 AM
JDMs1eeper's Avatar
Default Re: (Turbo-charged)
the Pulser is a nifty option, great to use if used correctly.
EF9*Hottie
Paint and Body
Oct 10, 2007 11:14 AM
.:Made in OC:.
Mar 14, 2007 09:58 PM
My48ur8
Feb 4, 2006 10:42 PM
@irborne
Welding / Fabrication
17
Nov 6, 2005 04:32 PM
99b18
Feb 19, 2004 08:27 PM
