no turns/hazards... ICU???
so i dont have any turn signals or hazards and ive replaced the fuses, the hazard/turn signal relay, and the hazards button... some one said that the integrated control unit on the back of the fuse box is most likely causing this problem... is this true?
well then what would be causing my turn signals AND hazards not to work considering i have replaced everything else and i even tried the turn signal switch too now and all my wiring is fine... but my marker lights work fine also...
could be icu. any integrated control unit is an ICU. There are ICU's for wipers,engine oil pressure indicator, side marker, engine control systems, brake bulb check and so on. Also 95s have a fuse in an auxiliary fuse box. The fuse is number 26 (10 amp). If this fuse was bad it would cause your problem. It delivers accesory power for exterior lighting. The only exterior flashers that work without acc power are hazard. Would have liked to help sooner but I'm new and my posts are limited to 5 in 24hrs. Oh yeah, only 95s have this fuse for some reason.
EvoEK9
Jan 26, 2008 10:15 AM
