code 19 man down
Old Mar 12, 2008 | 03:49 PM
El pimp chulo's Avatar
Default code 19 man down
1991 honda civic hatch dx 1.5 non vtech manual trans, my car is stick shift and my car wont start i bought it that way the ecu is giving me code 19 thats 19 blinks in a row every where i look on the web they say lock-up control solenoid valve (Torque Converter Clutch ) for automatic transaxle but my car is not automatic and it wont start
Old Mar 12, 2008 | 03:51 PM
crxricer66's Avatar
Default Re: code 19 man down (El pimp chulo)
maybe a no brain idiot put a auto ecu in not knowing before?? whats the side say on the ecu
Old Mar 12, 2008 | 03:54 PM
Default Re: code 19 man down (crxricer66)
its a pm five
Old Mar 12, 2008 | 06:32 PM
Former User's Avatar
Yeah, you definitely need to sort out a possible ECU mismatch problem. In the meantime, you also might want to test whether the "no start" issue is associated with a fuel or spark problem:
1) Do you hear the fuel pump activate (hum) for a few seconds after you turn the ignition key to ON?
2) Do you detect spark at each plug when the engine is cranking?
Old Mar 12, 2008 | 07:23 PM
91_Civic_Hatch's Avatar
Default Re: code 19 man down (RonJ@HT)
Code 19 is for the auto tranny, but I don't know why it won't start. Some deuche sold me an auto P30 ecu and failed to tell me it was for an auto. My car still starts and runs, it just throws the code 19. So maybe it could be something else. Just trying to help. I also have a manual PM5 if you want to buy it.
Old Mar 12, 2008 | 07:31 PM
DailyDriverCivic's Avatar
Default Re: code 19 man down (91_Civic_Hatch)
I have a code 19 on my manual swapped 90 EX. The code is for the torque converter solenoid. My car runs fine with this code.
Old Mar 13, 2008 | 09:41 AM
manuelesr's Avatar
the fuel pump is on but i dont get spark this is the third ecu i tryed first two didnt work i changed the dizzy cap rotor wires plugs battery checked grounds power at the dizzy checked main relay checked fuses check all conections and all but still no spark i even checked and cleaned the ground on the thermostat housing all i get is a stedy check engine light and a code 19 please help iv been [freak]ing with this car for about two weeks and it really getting to me now
Old Mar 13, 2008 | 10:18 AM
Default Re: code 19 man down (manuelesr)
You should troubleshoot the distributor coil and igniter with a multimeter. Also check whether the timing belt has snapped.
Old Mar 13, 2008 | 10:24 AM
crx(gator)'s Avatar
get a new distributor already...
Old Mar 13, 2008 | 02:14 PM
manuelesr's Avatar
Default Re: code 19 man down (username=no more)
i bought a new distributor already and checked the ignition coil the ignition module and the pick up all tested good like i thought they would the timing belt is fine i hade it timed to
Old Mar 13, 2008 | 02:59 PM
If you have power to the dizzy connector and new plug wires and plugs yet no spark, then the problem must be somewhere in the dizzy.
Modified by RonJ@HT at 6:10 PM 3/13/2008
Old Mar 13, 2008 | 03:02 PM
manuelesr's Avatar
every part of the dizzy is new and checked all the parts already all is well
Old Mar 13, 2008 | 03:09 PM
I completely understand but, based on available information and logic, you should reconsider a possible dizzy problem.
sgallagher's Avatar
So..you're not getting any spark whatsoever? A new distributor should include the ignitor and coil which I have seen both fail many times. Is it the correct distributor?
Try a different ECU?
Old Mar 13, 2008 | 05:52 PM
si vtec ftw's Avatar
Default Re: code 19 man down (sgallagher)
mess with your timing.
kind of a no brainer but i did the same thing.
the dizzy should rotate about 10 or 15 degrees. my car wouldnt start when the timing was off
just mess around with it
Old Mar 14, 2008 | 11:30 PM
manuelesr's Avatar
Default Re: code 19 man down (si vtec ftw)
ok i got the car to run but now when i give it gas it lags power and the more gass i give it the more it lags and it sounds like this putt putt putt putt putt putt and an ocassional putt comes out of the intake manifold
Old Mar 15, 2008 | 01:22 AM
D16SiHatch's Avatar
could be a dumb question but do you have the firing order right?
Old Mar 15, 2008 | 07:13 AM
manuelesr's Avatar
Default Re: code 19 man down (D16SiHatch)
your the man
EJCivJdM93
Jan 26, 2005 03:48 PM
tiresmoke
Feb 26, 2004 05:57 AM
1990hondaHF
Aug 20, 2003 04:16 AM
absolut b18
Aug 3, 2003 12:38 PM
done
Oct 8, 2002 03:52 PM
