How to roll your back fenders when you have a +15 offset using Sportmax 501's on a EJ/EG help!!
Old Mar 12, 2008 | 03:42 PM
94EJ1Coupe's Avatar
Default How to roll your back fenders when you have a +15 offset using Sportmax 501's on a EJ/EG help!!
anyone know how to roll back the back fenders on a EJ or EG? Just bought sportmax 501's ???? help!!!!
Old Mar 13, 2008 | 12:51 PM
nabin's Avatar
Default Re: How to roll your back fenders when you have a +15 offset using Sportmax 501's on a EJ/EG help!!
i need to roll mine too, anyone got insight? mine RUB!
Old Mar 13, 2008 | 01:14 PM
spock_rocker's Avatar
memoryFAB.com representative
look up eastwood fender rolling too. but youll need some negative camber as well to get those wheels to fit
Old Mar 15, 2008 | 08:24 PM
nabin's Avatar
that **** cost 250 man..... any other way?
Old Mar 15, 2008 | 08:27 PM
ejoner's Avatar
Heat gun and baseball bat.
Old Mar 15, 2008 | 08:32 PM
nicks-eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">Heat gun and baseball bat.</TD></TR></TABLE>
i was going to say a 12 pack and a rubber hammer
Old Mar 15, 2008 | 09:25 PM
DCSportEJ1Civic's Avatar
my friends wedge a screw driver between the fender and tire, then have someone drive the car forward slowly so the tire drags the screwdriver around the fender and pushes it out evenly all the way around. kinda ghetto way to do it but it works.
Old Mar 15, 2008 | 09:26 PM
oh, make sure you have a good grip on the screw driver and are ready to walk with the car while it moves.
Old Mar 15, 2008 | 10:42 PM
kcjohnnyboy's Avatar
how do you do that to prevent chipping of the paint due to the metal stretching?
Old Mar 15, 2008 | 11:08 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (kcjohnnyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcjohnnyboy &raquo;</TD></TR><TR><TD CLASS="quote">how do you do that to prevent chipping of the paint due to the metal stretching?</TD></TR></TABLE>
With the screwdriver method, I'm guessing they said "Screw it." With the tool Spockrocker posted, you'd use a heatgun on the fender lip for awhile, then roll. While that tool is expensive, its also very easy to use and produces great results.
&lt;--- Has tried several methods of rolling, that tool is the best. Hammer is second best, if you don't care about your paint too much
Old Mar 15, 2008 | 11:33 PM
nabin's Avatar
Default Re: (Stinkycheezmonky)
well ive gpt fresh paint so whats my best method?
Old Mar 15, 2008 | 11:40 PM
shadohconspiracy's Avatar
find someone local that can let you rent a roller for a day. thats what i did.
Old Mar 16, 2008 | 06:05 AM
Suspetise...
Default Re: (shadohconspiracy)
Yep. There are a decent number of people with these that rent them out. Just make sure you get the heatgun thing too.
Old Mar 16, 2008 | 06:34 AM
jwerks's Avatar
Default Re: (nabin)
what's up man (nabin) my hommie has one, I'll drop it off at your pad, you still have that el right, ???
Old Mar 16, 2008 | 06:57 AM
ive used a baseball bat and chipped my rear fender(bondo i guess) and a rubber mallet worked for the front if you go slow. i wished i wouldve had that tool.. its alot more effective
Old Mar 16, 2008 | 07:03 AM
JDM_SOHC's Avatar
Default Re: (spock_rocker)
i just did this yesterday after i did my brakes...
what i did was took a 14mm wrench, placed a handrag over it an with my car jacked up i laid the wrench flat on that area that was stickin out an pushing with force id slide the wrench up an down using the flat side of the wrench an that **** seemed to work pretty good... lil paint started crackin but w/e im goin in paint booth in like 3 months...
Old Mar 16, 2008 | 08:36 AM
use the handle and hold the metal part. sorry for not being specific. i kinda forgot cause ive never done it myself.
Old Mar 17, 2008 | 07:28 AM
nabin's Avatar
Default Re: (jwerks)
jwerks - nah man i dont have the El anymore, traded it for a Ek..... but i need to roll the fenders on my EG..... PM and we can work think out.
Old Mar 17, 2008 | 08:00 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EJ1Coupe &raquo;</TD></TR><TR><TD CLASS="quote">anyone know how to roll back the back fenders on a EJ or EG? Just bought sportmax 501's ???? help!!!!</TD></TR></TABLE>
Roll the fenders or just crush the lip? If you're rolling the fenders, you should use a fender roll tool. If you're just crushing the lip, use a heat gun/hair dryer and a mallet.
Old Mar 17, 2008 | 08:06 AM
nabin's Avatar
i wanna crush my lip in the back, but i dont want to crack my paint on the outside..... is that possible?
i thought "roll" and "crush" were about the same meaning.
Old Mar 17, 2008 | 09:42 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nabin &raquo;</TD></TR><TR><TD CLASS="quote">i wanna crush my lip in the back, but i dont want to crack my paint on the outside..... is that possible?
i thought "roll" and "crush" were about the same meaning.</TD></TR></TABLE>
Nope.
This is a roll. I used a fender roller and have the whole car re painted and the upper fender needed work because it collapsed (expected). It's more involved :
(17X10 +12 FNO1RC on an S13)
You can crush without chipping by Heating the paint up pretty good with a heat gun or hair dryer and then using a rubber mallet to SLOWLY crush it in from front to back or back to front. SLOWLY means crush it in incriments. Go back and forth. SLOWLY.
This is a crush.
(ADVAN RG2 17X9 +45 on a S2000)
Old Mar 17, 2008 | 12:32 PM
nabin's Avatar
well roll or crush, either way i dont wanna eat up tires when im slammed, and looks like it will now..
that fender rolling tool, will it crush the lip? im more interested in just crushing the inner lip back without messing up my paint
Old Mar 17, 2008 | 02:10 PM
spotscivic's Avatar
i took a angle grinder with a cutting wheel and just trimed it down and sealed it up again to protect aginst rust!
Old Mar 17, 2008 | 02:27 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spotscivic &raquo;</TD></TR><TR><TD CLASS="quote">i took a angle grinder with a cutting wheel and just trimed it down and sealed it up again to protect aginst rust!</TD></TR></TABLE>
That's how the pros do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nabin &raquo;</TD></TR><TR><TD CLASS="quote">well roll or crush, either way i dont wanna eat up tires when im slammed, and looks like it will now..
that fender rolling tool, will it crush the lip? im more interested in just crushing the inner lip back without messing up my paint</TD></TR></TABLE>
Yes you can crush the lip with a fender roller. BE CAREFUL. GO SLOWLY. You wont chip the paint with a rubber mallet either. If you crush it down too far, you will chip the paint anyway .....fender roller or not. You need to heat the paint up to do either, and the paint will only "stretch" so far before it cracks. Buy some touch up paint and just kinda put a coat on it with the brush after wards whether it chips or not. It doesn't hurt.
If you get an alignment for toe, your tire wear issues will be far less.
Old Mar 17, 2008 | 09:26 PM
nabin's Avatar
so should i just cut this **** off with an angle grinder?
