EGR removal difficulties
Old Mar 12, 2008 | 03:38 PM
KaoSyN's Avatar
Default EGR removal difficulties
Im ona 97, and Ive tried searching. I got a cel saying insufficient flow so I first want to try cleaning the egr before I port the plugs. Only thing is I cant get the two nuts off for the life of me. Ive tried using an extension but the real problem is that I cant get a good bite on it. On the other nut I can get a bite but I have no room turn it. I tried buying a swivel but the egr itself still blocks it from getting a good bite. Im starting to strip them so I wanted to see how you guys did it before I screw myself even worse.
Old Mar 12, 2008 | 04:48 PM
nemesis25's Avatar
Spray some PB blaster, let it sit overnight. Go to Sears and get a Bolt out kit for about $60.
Old Mar 12, 2008 | 05:44 PM
Acidcrakker's Avatar
Default Re: EGR removal difficulties (KaoSyN)
Get a wobble extension. And use a small socket. Works every time.
Old Mar 12, 2008 | 05:51 PM
no1knows908's Avatar
Default Re: EGR removal difficulties (Acidcrakker)
The only thing I could get to sit fully on the nut was a 1/4 drive short socket with an extension. The small diameter of the 1/4 drive extension had just enough clearance around the edge of the valve.
Old Mar 12, 2008 | 05:56 PM
Default Re: EGR removal difficulties (no1knows908)
a wobble flexes making the angle you can get to easier with a regualar socket set. And its ten bucks...
Old Mar 31, 2008 | 09:17 PM
gstrudler's Avatar
+1
Use PB Blaster and a wobble or closed-end wrench. Worst case, if you start to strip it, I've used a little JB Weld on the wrench (or socket) to make sure it keeps a good bite, then just clean it once it's free. Also, it's better to use short impacts on the wrench as opposed to sustained pressure.
jordy478
Aug 7, 2012 08:47 PM
untitled23
Apr 29, 2010 02:36 PM
thw_goalie
Feb 3, 2007 06:10 PM
AdReNaLiN
Apr 2, 2006 01:57 AM
OTT
Mar 1, 2004 11:11 AM
