Need help on Breather Box Install on a B20
Old Mar 12, 2008 | 01:52 PM
HONDACURA-DB8's Avatar
Default Need help on Breather Box Install on a B20
I've read that its optional to have this installed but as far as this being my first cr-vtec build, I want it done right. I've seen where they have tapped 2 holes on the front side of the valve cover and also heard that it can be tapped from the back of the b20 block. MY engine is on a stand so it will be easier for me to do this but I need a lil help from the H-T family. My current setup is a B20b block with a GSR head and a blox manifold. I want to tap it from the back but not sure where. I'll post pics later of my setup. Thanks H-T for the help!
Old Mar 12, 2008 | 08:39 PM
dmotoguy's Avatar
Default Re: Need help on Breather Box Install on a B20 (HONDACURA-DB8)
there are (2) 14mm Allen Plugs on the back of the block, take those out, then buy the ones off of a prelude? that have nipples for hose on them, or get the ones from B&R fittings that have -10an fittings built into them.
Old Apr 16, 2008 | 05:44 AM
B20Concerto's Avatar
Can anyone tell me what model Prelude has these plugs.
Old Apr 18, 2008 | 03:26 PM
92integraVTECgsr's Avatar
Default Re: Need help on Breather Box Install on a B20 (B20Concerto)
I believe the ones from an LS will work too.
calishowa
64
Mar 27, 2015 06:54 AM
typeR4u
Feb 25, 2015 10:53 AM
juanintec
Oct 15, 2007 11:08 PM
2ndgentegracer
Aug 22, 2006 07:09 PM
gsr984dr
Sep 26, 2005 04:13 PM
