Which distributor to use with JDM h22a motor/usdm h23a harness?
Old Mar 12, 2008 | 10:58 AM
socialistic's Avatar
Default Which distributor to use with JDM h22a motor/usdm h23a harness?
I have both the h23a external coil+distributor, and the h22a internal coil distributor. I'm told I have to use the external coil distributor, and would have to modify a plug if I wanted to use the h22a internal coil one.
What plug do I have to modify, and what exactly needs to be changed? I'd prefer using the internal coil distributor, so I don't have to worry about mounting the h23's coil anywhere.
This is in a '93 Prelude Si with a JDM p13 ecu. I searched around, even tried google, and all I can really find is h23-to-h22 swaps in Accords...and a lot of that info doesn't apply to me.
Old Mar 12, 2008 | 11:00 AM
Pullig's Avatar
Default Re: Which distributor to use with JDM h22a motor/usdm h23a harness? (socialistic)
just use the external coil dizzy
socialistic
Jun 14, 2008 09:39 AM
HybridKOOP
Jun 28, 2007 09:06 AM
ekmotorfiend
Oct 29, 2006 12:38 PM
fuckaBitch16
Mar 7, 2006 12:45 PM
satan_srv
Nov 14, 2002 02:55 PM
