Need help with removing hub to install studs???
Old Jul 8, 2002 | 05:57 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Need help with removing hub to install studs???
1-I already took the break calipers out
2- Took the other piece that connects to the caliper out
3- Took the 6 mm screw out from disk break
4- Took disk break out
How can I take out the hub to install my studs for my bogrt. The easiest way please
[Modified by Civicdrgrcr, 2:57 PM 7/8/2002]
Old Jul 8, 2002 | 06:03 AM
DSF's Avatar
DSF
Default Re: Need help with removing hub to install studs??? (Civicdrgrcr)
Take the knuckle off and head to a machine shop (or any shop for that matter) with a hydraulic press to press the hub out. You "can" do it yourself with a large enough socket and hammer, but you risk damaging the wheel bearings.
Old Jul 8, 2002 | 06:55 AM
Jared's Avatar
I have put civic studs in without pressing the hub out. if you'll use a grinder and make the circled end of the stud into a halfmoon shape, you can get them in there.
Old Jul 8, 2002 | 07:21 AM
AGen2integra's Avatar
Default Re: Need help with removing hub to install studs??? (DSF)
I would definately recommend going to someone with a press, I ended up spending more money replacing my bearings after f@*%ing them up trying to do it my self.
legendboy's Avatar
Default Re: Need help with removing hub to install studs??? (Jared)
Holy **** Jared!!!!!!!!! That is a *uckin good idea!! I had to do it 2 weeks ago and we getto rigged it using 2 blocks of wood, 1.25" socket, 1.5" brass punch..etc...what a headache, Good thinkin man!
Old Jul 8, 2002 | 07:28 AM
DSF's Avatar
DSF
Yep, I've done that on my beater cars. But, my ***umtion was that if he is running Bogarts, he is running a good amount of hp at the track and hacked up wheels studs would make me worry a bit
Old Jul 8, 2002 | 09:45 AM
yeah. So best thing to do is take it to a shop and let them install it for me.???
stealth_EK4
Honda Civic (2001 - 2005)
Apr 11, 2008 08:23 PM
RTW DC2R
Feb 13, 2006 08:21 PM
TegBen
Mar 20, 2005 06:56 PM
9seccivicsi
Feb 11, 2004 06:07 AM
Night_Minx
Aug 19, 2002 07:48 AM
