plz need help brake padel problem
hello
yesterday i change the left side brake disc of my accord 1990.now when i brake the car the brake padel move up and down.plz can any one tell me why its doing that and how to fix this problem.
Thanks
Thanks
yes i replace one side rotor and both thickness are same.the pads i used old ones cuz they are in good shape and i didnt did bleeding so do i need to do bleeding of all wheels?
Does the padel vibrate or slowly go down when you press the padel?
If it vibrates, that is a problem related to the rotor. If it did not vibrate before you changing the rotor, it might because the old pads can not work very well with the rotor. Give a few days drive and check again.
If the padel slowly goes down, you need to check leaks and bleed the brake line.
You should have changed the pad for the left side while you changed the rotor. The old brake pad may be uneven. I would have suggested cutting the right side and change all the front brake pads at that time.
